Question about HP C6280 All-in-One Printer
HP C6280 will not print self test diagnostic
What is the usual diagnosis or outcome when an HP won't print a correct Self Test Diagnostic, containing diagnostic data, from the control panel? It printed it one (won't print another because of multiple errors), but was missing ALL data from boxes & sections of 2 pg. report - except color sample boxes (looked fine).........Gone through usual printer reset steps: power reset; clearing hardware error codes. That clears 1 (or more) errors, but they re appear........The errors just rotate - clear 1, another pops..... Carriage or paper jam (neither true);... ink system failure (printed perfect text, lines & color boxes on self test);... pump motor stalled.... DON'T think ink motor is stalled or not working. Printed perfect lines, headings & color boxes on self test.... With top cover off, can see all pump gears, belt turning normally in warm up. Pump sounds normal during printer prep. Is it just fried? Had a power outage - but it was on surge protector, ALONG w/ modem, router, VOIP ATA, PC. None were damaged....Plugged printer into wall outlet - no change.
Posted by Ben Do on
david willimes
    Sergeant:
  • 260 Answers
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Posted on Nov 05, 2015
1 Related Answer
NinaE
  • 3278 Answers
SOURCE: HP Photosmart C7280 - Error:Oxc18a0001
Hello.
Give this a try (from HP Support):
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Hope this resolves your problem.
Posted on Nov 23, 2010
Were is engine light fuse 05 ford focus
There isn't a fuse just for the check engine light fuse . There are fuse's that power the whole insturment cluster . Check engine light not working ?
  • The malfunction indicator lamp (MIL) is never/always on
  • Circuitry.
  • Powertrain control module (PCM).
  • Instrument cluster.
  • Go To Pinpoint Test O .
PINPOINT TEST O: THE MALFUNCTION INDICATOR LAMP (MIL) IS NEVER/ALWAYS ON Test Step Result / Action to Take O1 RETRIEVE AND RECORD THE DTCS FROM BOTH CONTINUOUS AND ON-DEMAND PCM SELF-TESTS
  • Key in OFF position.
  • Connect the diagnostic tool.
  • Key in ON position.
  • Enter the following diagnostic mode on the diagnostic tool: PCM Self-Test.
  • Check for PCM DTCs from the continuous and on-demand self-tests.
  • Are any PCM DTCs recorded?
Yes
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
No
GO to O2 . O2 CARRY OUT THE INSTRUMENT CLUSTER INDICATOR LAMP CONTROL ACTIVE COMMAND USING THE DIAGNOSTIC TOOL
  • Enter the following diagnostic mode on the diagnostic tool: Instrument Cluster Active Command.
  • Select the instrument cluster warning lamps and chime active command. Trigger the indicator lamps active command on then off, while observing the MIL.
  • Does the MIL illuminate when commanded on and turn off when commanded off?
Yes
GO to O3 .
No
GO to O4 . O3 CHECK FOR CORRECT PCM OPERATION
  • Disconnect all the PCM connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the PCM connectors and make sure they seat correctly.
  • Operate the system and determine if the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new PCM. REFER to Section 303-14 . TEST the system for normal operation.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. TEST the system for normal operation.
O4 CHECK FOR CORRECT INSTRUMENT CLUSTER OPERATION
  • Disconnect the instrument cluster connector.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect the instrument cluster connector and make sure it seats correctly.
Yes
INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation.
No
Jun 11, 2017 | Ford Cars & Trucks
I have a 04 explorer and I put anew fuel pump an my gauge on the gas hand still don't work but number 17 fuse is hot on both sides what is 17
Where ? under hood fuse box or inside fuse box ?
F1.17 20 Four-wheel drive control module (14B466)
F2.17 15 Battery saver relay, Accessory delay relay
Visual Inspection Chart Mechanical Electrical
  • Engine oil level
  • Door adjustment
  • Engine coolant level
  • Fuel tank
  • Fuel evaporative system
  • Battery junction box (BJB) fuse 15 (5A)
  • Central junction box (CJB) fuses:
    • 15 (5A)
    • 21 (5A)
  • Miniature bulb(s)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the concern is not visually evident, connect the diagnostic tool to the data link connector and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card or disk is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • SCP or UBP circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the instrument cluster, Go To Pinpoint Test G . For vehicle security module, refer to Section 418-00 ; for anti-lock brake system (ABS), refer to Section 206-09 ; for restraint control module, refer to Section 501-20B .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out self-test diagnostics for the instrument cluster.
  1. If the DTCs retrieved are related to the concern, go to the Instrument Cluster Diagnostic Trouble Code (DTC) Index or the Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics. For all other DTCs, refer to Section 418-00 .
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart to continue diagnostics.
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self diagnostic mode with the engine off, press and hold the odometer reset button (base cluster) or the message center reset button (message center cluster). Turn the key to the RUN position and hold until the display indicates tESt (base cluster) or TEST (message center cluster) usually within three to five seconds. Depress the reset button once to advance through each stage of the self-test.
To exit the instrument cluster self-test mode, turn the ignition to the OFF position. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
  • Incorrect fuel gauge indication
  • Circuitry.
  • Fuel level sensor.
  • Fuel pump module.
  • Fuel tank.
  • Go To Pinpoint Test H .
You need to test , don't guess ! Your best bet would be to take your vehicle to a qualified repair shop .
B1201 Fuel Sender Circuit Failure Instrument Cluster Go To Pinpoint Test H . B1204 Fuel Sender Circuit Short to Ground Instrument Cluster Go To Pinpoint Test H .
Jun 07, 2016 | 2004 Ford Explorer
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: [email protected]
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
Radio on C6180 not working and printer won't print
Try to unninstall the driver then put it again, it should work
Dec 05, 2011 | HP Photosmart C6180 All-In-One InkJet...
It is not working with the HP cq60-615dx laptop. No signal from the M1 cable. but it work on a desk top i don't get it.
Ensure that all the cables are securely connected. See "Connecting Your Projector" on page 7."
Ensure that the pins of the connectors are not bent or broken.
Run Self-diagnostic test. See "Self-diagnostic for Video" on page 26. Ensure that the colors
of the test pattern are correct.
Dec 16, 2010 | Dell 3400MP Multimedia Projector
My C5180 won't print. It sounds like it is printing but spits out a blank page
>try the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449854&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1153481&lang=en
.also check if there is still ink on it try printing a self test page
Method one: Print the page from the control panel
  1. Load letter, A4, or legal, unused plain white paper into the main tray.
  2. Press the OK and Help buttons at the same time and then release them. The self-test diagnostic page prints.
Method two: Print the page from the computer
  2. Open HP Solution Center.
    • Windows Vista: Click the Windows icon (c01364735.gif ), click All Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click the Settings menu, point to Print Settings , and then click Printer Toolbox .
  4. Click the Services tab, and then click Print test page . The self-test diagnostic page prints.
Oct 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP C6280 All-in-One Printer Logo
109 people viewed this question
Ekse
efs_perpends
efs_perpends
