Hi First i was not able to see in bios that usb(hard disk) is coonected with pc then i changed the hard disk now able to see the usb as i do f10 and save then esc for the setup i select the usb gain suddenly the error message apper please insert the hard disk why am getting this error? regards Malu
SOURCE: pc cant boot
check the jumper settings, for this take out the hard drive and check the small jumper should be attached to master point. your cd rom should be on the slave the same way...reconnect the hard drive and restart ..after restarting goto bios . advanced configuration> boot options>first boot device> select hard disk and save exit. restart the pc
SOURCE: HP Pavillion freezes up on the HP Invent splash screen
Don't throw out that computer or replace any components just yet.
After much trial-and-error, I finally figured out the solution for this common issue with certain HP Pavillion models. It turns out to be a design flaw with the front-panel memory card reader. Somehow the card reader's firmware gets scrambled, and it prevents the computer from booting. You can test this on your machine by temporarily disconnecting the card reader cable at the motherboard header. Voila - I'll bet you $1 that your computer will now boot!
The solution is buried deep inside this HP tech support document. The card reader firmware needs to be reset.
Here\'s how to fix it once and for all:
1) With the computer power unplugged (duh), open up the case & disconnect the card reader cable at the card reader itself - NOT the end that connects to the motherboard header. Make sure the cable end is not touching any metal components before proceeding to step 2 (another duh).
2) With the cable still disconnected, fire up the computer. The tech support doc says to let it boot into Windows and stay there for about 5 minutes.
3) Shut the computer down and reconnect the cable to the card reader.
4) Turn your computer back on - your memory card reader will work and, most importantly, the computer will no longer hang at POST!
I suspect that when you fire up the computer without the cable connected, the card reader is designed to reset its firmware by grounding out through the case - sort of like a CMOS Reset jumper on a motherboard.
I hope this solution is helpful to others.
best,
JohnB
SOURCE: Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
SOURCE: I have a HP Compaq dx2200 microtower. When I turn
Ed it sounds like a RAM problem. How much ram do you have. These days you need at least 1g. How big is your hard drive. You need to have at least 10g constantly free at all times. This might mean a larger one. You may be running 2.0 devices but is your system truly 2.0 or higher. Go to start, run, try this:
At this point you should see something like this:
"... on most machines the presence of
'Enhanced', even only once, means that all USB ports are USB 2.0 ports
Note the highlighted line: "Standard Enhanced PCI to USB Host
Controller". While the exact text may vary, the key is the word
"Enhanced".
If it's "Enhanced", it's USB 2.0. If it's not, then it's USB
1.x.
Now, wasn't that obvious?
Important: on most machines the presence of
"Enhanced", even only once (which it typically is), means that
all USB ports are USB 2.0 ports. Typically a machine will have only one
type of port and this tells you which kind they all are.
The one exception to this scenario is a machine with USB 1.1 ports
that has a USB 2.0 expansion card added. In this case I know of no way
to tell which is which, other than simply knowing you added a USB 2.0
card to a machine with built-in 1.1 ports. Obviously in a case like
this, the built-in ports are 1.1, and the added expansion card ports are
2.0.
Hope this helps.
JimmyC
SOURCE: strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
