Question about GE WBSR3140DW Top Load Washer
Can i ajust the water level to go higher - GE WBSR3140DW Top Load Washer
Posted by tim babin on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
No,its a set level mandated by the epa (environmental protection agency) and the doe (dept of energy) to conserve water and energy it will tell you this in the owners manual
Posted on Mar 16, 2013
To much water presure
just needs ajustment need to take the shroud off and a screwdriver
Jul 17, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
How do I ajust water level for more water for wm2240cw hardly adds water
water level is automatically set and adjusted for volume and type of clothing. (at a low level, below the bottom of the door) If you select a delicate cycle, the water level will be slighly higher. These water levels are all that is required to clean in these machines. Take that into account when adding your laundry detergent. Old top load machines used 40 or more gallons per cycle. Your machine uses about 13 gallons, so you should only be using 1 to 2 tablespoons of HE laundry detergent per load. (only 1 teaspoon of fabric softner if you use it)
Mar 05, 2011 | LG Washing Machines
What is the problem when water is running on a dual flush toilet
water level set to high push botton rods not ajusted rite 5 year warranty on flush valve
1-800-459-4409 service and parts
Jan 21, 2011 | Toto Aquia II Dual Flush Toilet
Can you ajust water level to be more in washer
No.
As with all modern machines your senses the size of the load and adjusts water levels accordingly. Unlike older machines, this means that less water is used and less energy is used to heat excess water. It also means that you get a better wash as the cleaning quality is lower if the load is sloshing about in too much water.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Jan 23, 2010 | Dishwashers
When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Oct 31, 2009 | Home
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
GE WBSR3140DW Top Load Washer Logo
116 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
