Question about Home Security
The 953EV/EVC remote is designed to work with garage door openers at 315MHz (more or less). Your older unit doesn't work at that frequency. I'm not positive but it could be 300MHz.
You need a retrofit unit to use the new remote. See https://aclickawayremotes.com/Liftmaster/355LM-2-315-Mhz-Garage-Door-Opener-Conversion-Kit/index.html for one that works with Chamberlain units.
I hope this helps.
(who has 2 pre-1993 garage door openers and two post-1993 units on various buildings. Yes, we run around with 2 remotes everywhere.)
Posted on Mar 13, 2013
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
SOURCE: Replacement for Garage Door Remote
The red button is the "learn" button. No resets.
Posted on Mar 25, 2009
SOURCE: Universal garage door remote
I have a feeling your neighbor operated their door opener when you were programming your new clicker. Try erasing the memory of your opener and then program the clicker again making sure your neighbors do not operate theirs at the same time. To erase the memory hold the smart/learn button in for 10 seconds.
Posted on Jul 22, 2009
SOURCE: Chamberlain Whisper Quiet garage remote won't work
There isn't a trick but you must make sure you got the right remotes for your opener. The receiver which is part of the logic board can quit working and it sounds like this may be the case in your situation.
Posted on Sep 14, 2009
May 05, 2014 | Chamberlain 953EV Garage Remote w/...
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Mar 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Oct 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Feb 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dec 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Apr 05, 2009 | Chamberlain 950CB Remote Control
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
727 people viewed this question
