GE Microwave Model JVM1430... it just stopped working.... Changed the fuse and was able to set the clock. As soon as we opened the door to put something to reheat and shut it closed, it "died" again on us. What could be the problem? This is the 3rd fuse we have put in in the last 6 months
SOURCE: GE Spacemaker microwave XL1400
If you or a friend decide to work on it, we have *critical* safety,
disassembly, and troubleshooting info at our site, and our link is at
our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you remove the vent grille held on by screws and/or clips then you'll see a screw at the top of the control panel.
Then the control panel should either lift up and out or forward and down.
The fuse is normally near the door switches, on the floor behind the controls, or on a metal plate near the transformer or fan.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The actual model number is like JVM1460. XL1400 is just a "line" and won't help in finding parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes
Failure
Code
Condition
Check/Repair
F1
Open sensor, will
occur below 190F of cavity temperature within 15 minutes after
starting convection, combination or roast cook
Check oven temperature
sensor for continuity. Replace if zero or infinite ohms
F2
Shorted thermal
sensor, will occur if a shorted thermal sensor is detected
continuously over 5 seconds on convection, combination or
roast cooking
Note: It will take a minimum of 5 minutes of convection run
time before F1 or F2 code will be displayed if the thermal
sensor is shorted or open.
F3
Shorted key panel
(touch pad), will occur if a shorted key panel is detected
continuously over 60 seconds
Replace key panel
(touch pad)
F4
Open humidity
sensor, will occur if humidity sensor is detected as being
open continuously over 5 seconds
Replace humidity
sensor
F5
Shorted humidity
shorted continuously over 5 seconds
Replace humidity
sensor
F6
Shorted temperature
probe, will occur if temperature probe is detected as shorted
Replace temperature
probe
ProbEe
Open temperature
probe, will occur if temperature probe is detected open, or
not plugged into the receptacle
If probe is plugged
in and "ProbE" is on display check continuity of the probe
with an ohm meter. If zero or infinite ohms, replace it
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the mount is broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: GE Microwave Model JE1640WA runs when the door is open only
You probably have a loose or broken door switch mount or the door may be slightly misaligned.
See:
http://www.microwavedisplay.com/safety.txt
and
http://www.microwavedisplay.com/disassembly.txt
and
http://www.microwavedisplay.com/doorsw.txt
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
You can find
model number from the tag on the oven here.
We're
SOURCE: GE Spacemaker XL Microwave Oven Model
Your membrane keypad is wearing out.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
The keypad is part number WB27X10171 and you can get it here for $91.68 plus shipping.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
We're
Testimonial: "Thank You. "
