I reloaded a optima 45 but when I tried to push the tray back in it seemed like the spring had broken and now it won't push the staples forward to use?? I don't see how to get it apart to realign the spring.
Posted on Feb 12, 2018
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
SOURCE: I have a Swingline Optima Heavy duty manual
You may nave too many staples remove half of them and see it that helps
Posted on Mar 11, 2010
SOURCE: Swingline Stapler 900XD -
Help! I have a swingline 900XD and the device that holds the staples in place is missing. Does anyone have an idea how to fix it???
Posted on May 12, 2010
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
Aug 29, 2013 | Swingline 48209 Optima ® 45 Electric...
Feb 15, 2013 | Swingline 48209 Optima ® 45 Electric...
Apr 24, 2012 | Swingline 87845 Optima ® 40 Desk Stapler
Jul 21, 2011 | Office Equipment & Supplies
Mar 10, 2010 | Office Equipment & Supplies
Sep 15, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
15,378 people viewed this question
