Question about Kenmore Freezers
Kenmore freezer buzzer
We turned off/unplugged our freezer overnight to defrost. Today we pugged it in, then turned on the power switch. A loud buzzer alarm went off immediately. We have done this defrost several times in the past and never heard this alrm before. The shelf coils begin to cool, but the buzzer will not turn off.. There is nothing in the manual about this buzzer. Will it turn off after the freezer reaches its low temp. is something else wrong? is there a off/reset button for the buzzer? Thank you Nick
Posted by nicholas wolff on
Anonymous
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Posted on Mar 14, 2013
5 Related Answers
Anonymous
  • 523 Answers
SOURCE: Kenmore upright Freezer 20.3 cu.ft has 2 switches
its a temp alarm
Posted on May 26, 2010
Anonymous
  • 236 Answers
SOURCE: Top Shelf of Freezer Not Cooling
sounds like you may have a refridgerant blockage in the system. it may need a regas to see if it can be unblocked, as this is not a quick job it may cost you but phone around on the cost/feasibility of it. it may be just as well to get a new or second hand freezer.
Posted on Jun 06, 2007
Anonymous
  • 145 Answers
SOURCE: upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Posted on Apr 17, 2008
Anonymous
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
Anonymous
  • 323 Answers
SOURCE: low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Posted on May 12, 2009
I have an older model chest freezer. The alarm buzzer and light came on. I silenced the buzzer but the light is still on. The freezer is cold and still freezing well. Door is good and closed. It’s running...
Without a posted make and model number, it is hard to say. You need to unplug the unit from the power for a couple of minutes and then plug it back in to see if it resets
May 25, 2018 | Freezers
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
The temp on my freezer is on normal and was working ok then just stopped and the red light is on turned up the temp to make it colder and the fast freeze but not working and everything is defrosting
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Sep 24, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a fridgerdire freeze that has not beem used in a a while. We plugged it in today and I have a power light and a temperture alarm. When I turn the freezer on I hear a buzzer alarm going off and the...
Hi James.
Most Kenmore upright freezers use a backup battery located at the lower part of the appliance. When the battery is low the freezer will beep continuously. If the unit has been off for a long time, and if the unit uses a battery, then the battery may need replacement.
Here a picture of the battery in its housing, located in the lower front part of the freezer.
Feb 19, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Things are defrosting. Red light on bottom right side is one. When I turn on the on/off switch a buzzer/alarm sounds. Is this freezer dead?
It may be a malfunction causing this.
Check for ice buildup on the lower panel inside the freezer.
This will be a sign off a failed defrost component.
Check the fan motor in the freezer,is it running?
If not,that can be a problem.
Feel the compressor,is it running?If not,that can be a problem.
Jun 29, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Alarm buzzer went off and the yellow and redlights are "on."
The on/off switch is only for the alarm. Some people do not want the buzzer to sound for them. If your buzzer is going off then the temperature in the freezer is too warm. It usually means the door was not closed all the way or there is a malfunction in the cooling system. Check the door and seal, make sure it is closing all the way around. If it is and the alarm does not stop on it's own then you will need service done on the unit.
May 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
240 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
