Question about Logitech Z-2300 2.1 Computer Speaker System (3-Piece)
Z-2300 connector wiring diagram
Control connector
I need a wiring diagram to install, hard wire a brake controller Ford 1991 E350 van. Where to start looking for wires in cab area?
It all depends on the instructions that come with your brake controller. In 1991, the wiring diagrams published by the manufacturer were not real good at indicating locations of things. For most brake controllers, you only need to use the output side of the brake lamp switch, a direct battery positive circuit (Which would be best to run directly to the battery with an inline fuse), an "ignition" hot wire (which there is probably a connector in the underdash fuse block that is marked "fused Ignition" - there should be one right next to fuse # 14). And the wire that must be run to the back of the vehicle to the trailer connector.
It is really very simple and you should not need wiring diagrams to figure it out...just the instructions with your controller.
May 18, 2012 | 2004 Ford E-350 Super
Looking at vehicle module which is a port and b port
If you are refering to the Engine Control Module (ECM) for your 1987 Blazer, there are two connectors. One is the "A/B" connector (24 Pins) and the other is the "C/D" connector (32 Pins). The letters represent the rows in which a particuler wire or wire connector can be found. For example, if the wiring diagram shows the wire to be going to ECM connector B4, The actual location would be in the 24 pin connector at the ECM and would be the fourth wire in the "B" row of connector pins. SEE DIAGRAM BELOW.
Apr 10, 2012 | 1987 Chevrolet Blazer
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Pioneer deh-2300 wiring diagram please
here is the installation and user manual link see fig 4 installation manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2300R/index.html
Cheers!
Jan 30, 2010 | Pioneer DEH-2300 CD Player
Ned to wire speekers to my xr 2300 radio
As long as it is a newer model sony the speaker colors are: left front: white. left rear: green. right front: gray. right rear: purple. The black stripes are your negatives, solids, positive.
Aug 17, 2009 | Car Audio & Video
Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
Apr 16, 2008 | Car Audio & Video
Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
Apr 03, 2008 | Logitech Z-2300 Computer Speakers
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Logitech Z-2300 2.1 Computer Speaker System (3-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Vernon Taylor
Lawrence Oravetz
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
