Question about Sony RDR-VX555
Pulley belt 306779001
Need dimensions of this belt
Can anyone tell me Where to get or find the dimensions for the drive / pulley belt going to my 6 gal. central pneumatic air compressor? Model # 67696. Part # mx115249143876. Please?!
take belt to auto parts store to if you can match it There are no repair parts available not uncommon for hf budget priced air comp.
Jun 22, 2018 | Air Tools & Compressors
Purchased mower but does not have original 42' deck, how do I get belt replacement, original belt too short
Take a measurement of how short your belt is from the leading edge of your deck pulley when it's on the engine-or clutch pulley. Take the belt to a hardware store & have someone find another V belt of the same thickness (grade A, B, etc.) that fits your required dimensions. Take into account that the belt should be long enough for your belt tensioner. Belt manufacturers make belts of all lengths. Good luck!
Mar 08, 2016 | Garden
Tomberlin Firefox 620 CVT Belt #
System should be Asymmetric from factory (belt flat on motor side, tapered on the other).
If you have a 6" Diameter Driven (lower) pulley and the Center Distance (shaft center to shaft center) is around 7-3/16" you need this belt: http://www.beltpalace.com/co20rebe1.html
If same Driven unit, but about 6-3/4" Center Distance, use this one: http://www.beltpalace.com/manco5959.html
or it's high quality Comet version: http://www.beltpalace.com/stens255-299.html
Oct 01, 2012 | Cars & Trucks
I have an old westwood ride on mower and i've been told that the deck pulley I am trying to source is obsolete. Are there any dealers that may stock these obsolete parts????
Are you looking for it by its part number? If that is how you are looking for it, there may be a substitute part that is functionally identical, that will have a different part number. Also, do you know who makes the deck? For example a few brands of mowers use an AYP manufactured deck. You may be able to locate an acceptable substitute that way.
Aug 22, 2011 | Garden
My whirlpool washer does not spin, i open it up today and notice the belt on the spin wheel is twisted and around the wheel but not connect to the shaft. please help.
You will need to remove the belt and replace with a new belt. If the belt is broken kindly get the same type with the dimensions for replacement.
Place the belt on the drive wheel and run it over the motor pulley and manually turn it on so as to fit it into the slot.
Feb 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Want to bypass powersteering pump on 94 grand caravan 3.3 liter 6 cylinder, pulley making loud noise need new belt size and serpintine diagram if its possible
that's not possible all of those vehicles came stock with power steering so all belt dimensions are taking the power steering pump into consideration,the only one that would change would be the A/C belt depending on whether or not your vehicle came with it or not,a used power steering pump should only cost just a little bit more then a new serpentine belt,hope this helps and good luck
Jun 19, 2010 | 1994 Dodge Grand Caravan
How do I change the drive belt? On a Ridgid 13" thickness planer model TP1300.
You need to remove the right side cover, indicut knob, crank, and cutterlock knob. Remove the top cap (4 screws) crank the motor asssembly to the top exposing two hidden screws in side wall, remove those and the two at the top and remove sidewall. . Tension adjustemnt screw is right near the motor pulley. Loosen it and push motor inward while sliding belt over pulleys. It is a little tough getting the belt in between the pulley and main carriage. If you attempt to put the belt on one pulley at a time, you are working a diagonal, which is longer that the inline dimension. Apply a drop of liquid dish detergent to each pulley for lubrication. Start the edge of the belt onto both pulleys; making sure the splines & grooves are aligned on both pulleys. Slowly work the belt on, 32nd of an inch at a time one pulley, then the other. Wash the soap off when you are done'
Jun 12, 2010 | Ryobi Thickness Planer Blades
Hi. I've a washing machine rex electrolux logic RE7. I must change the belt but it seems too much hard for me because the belt is too much short but the new belt is the correct belt. how can do this in...
There are two types of drive belt with different characteristics:
• rubber belts (black)
• plastic belts (yellow)
belt for example: 1280 J 8
1280 = this is the working length which is always shorter compare to length of 1280 mm depending of degree of elasticity (plastic or rubber).
J or H = shape of the drive belt
4,5,6,8 = number of teeth
So, if dimensions, shape and number of teeth are the same as the original belt, proceed as shown pictures below:
Always first place the belt on the motor pulley and then on the drum pulley and then turn the drum pulley (big) and belt clockwise firmly until the belt is seated.
Dado
Jan 23, 2018 | Electrolux Washing Machines
Need a belt for a 14'' band saw model 20314 serial number is 901160
Run a tape measure around the outer rim of both pulleys and the space between them to get the total belt length and measure the space in between the two rims of one pulley for the belt width. You purchase the belt using those two dimensions.
Sep 26, 2009 | Saws
Sony RDR-VX555 Logo
57 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
