Android Coby Kyros Mid7014-4g 7" Tablet Logo
A
Anonymous Posted on Mar 12, 2013
Mi mid7014-4g no me trabaja me indica fastboot y no encuentro solucion
How unlouck bootloader
To unlock the bootloader on your Lenovo Tab3 7 Essential (TB3-710I) tablet, you need to follow these steps:
Note: Unlocking the bootloader will erase all data on your device. Make sure to backup your important data before proceeding.
  1. Enable Developer Options on your device. To do this, go to Settings > About tablet > tap the Build number 7 times.
  2. Enable USB Debugging. To do this, go to Settings > Developer options > enable USB debugging.
  3. Download and install the ADB and Fastboot tools on your computer.
  4. Connect your tablet to your computer using a USB cable.
  5. Open a command prompt window on your computer.
  6. In the command prompt window, type the following command and press Enter: adb reboot bootloader, This will reboot your tablet into the bootloader mode.
  7. Next, type the following command and press Enter: fastboot oem unlock, This will unlock the bootloader on your tablet.
  8. Once the process is complete, reboot your tablet by typing the following command and pressing Enter: fastboot reboot. That's it! Your Lenovo Tab3 7 Essential tablet's bootloader is now unlocked.
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
2answers
How to hard reset my supersonic tablet
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/or click on link below for direct download.
ADB Driver Installer (9.22 MB)next, install the ADB driver then you will see a USB root on notification area on your PC.
No comment next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
next, command prompt will open and you need to type these commands;
This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
No puedo entrar en recovery en mi tablet m752 y no enciende se queda en la pantalla de inicio existe alguna solucion?
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
5helpful
2answers
Mi problema es que se me ha olvidado el patron de desbloqueo
hola tengo una tablet cruz reader r101 y me olvide el patron de seguridad no puedo ingresar mediante el patron de la cuenta d gmail porque no aparece en mi tablet ,que solucion tendria para utilizar mi tablet,ayudenmeee ,cualquier cosa me escriben a [email protected] se lo agradeceria .graciasss
Tengo una toshiva satelite 1695cdt mi problema es que la formatie e instale xp sp 3 al principio funciono todo bien pero luego de reiniciarla me dejo de funcionar el cd rom, asi como el mouse interno y...
Try to open you laptop and clean all dust inside, search for the correct drivers of your laptop model. Windows xp is very annoying with specific drivers. Take in caution that your are free of any malware.
Top Android Tablets & eReaders Experts
Alison Lofts
Alison Lofts
August Brown
August Brown
Antonios
Antonios
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
