Question about U-Line ?chelon 2175RB-00
Digital screen says err
Unit compressor very hot screen says err when I unplug for an hr to cool down compressor it turns on just fine but later on it says err again and not cooling
3 Related Answers
Anonymous
  • 87 Answers
SOURCE: U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Posted on Aug 26, 2007
Anonymous
  • 61 Answers
SOURCE: 15WC wine captain. Unit
temp control is the only answer sorry the unit turns on with it and off with it .
hope this helps
Posted on Oct 20, 2008
Anonymous
  • 286 Answers
SOURCE: cools at start up....then gets warm..compressor is warm.
I would need to know the model of this. However if the condenser fan is Not runing then the problem is that. If it is then it could be the sealed system and you will need a tech to check it out.
Posted on Jun 07, 2009
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
2answers
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
4answers
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
3helpful
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
3answers
Compressor starts/stops alot. Compressor is hot coils are cool
Have you checked the power and the amps going to the compressor? Your compressor is getting hot and then it is freezing up and trying to going into cycle but the piston over heats and the relay cuts out the compressor, that is why when you let it cool down it works ok. You will need to get a new compressor. If you have a warranty the compressor is covered
Compressor and water are hot!
re-charge the freon. this will cool it down.
U-Line ?chelon 2175RB-00 Logo
Top U-Line Refrigerators Experts
Dale Copeland
Dale Copeland
Kardoc
Tom Chichester
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
