Question about Riccar Vacuums
Riccar 300c reset button - Riccar Vacuums
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
On the back at lower left. Its a little white button. It should be beside a tag that says "Reset Button"
Posted on Aug 11, 2014
1 Related Answer
Anonymous
  • 17 Answers
SOURCE: riccar 1500p vacuum won't start
it has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Posted on Oct 02, 2008
Riccar r30d I have checked the hose and tried the reset. The bag was just put on and I took it off and put on again. When I plug it in now the lights turn on but nothing at all happens.
When you press the reset button you must make sure to push it in far enough. You may need to use a small tool to make sure you are getting it reset. Your Riccar vacuum is still under warranty. If it is not the reset button I suggest you take it back to your dealer for repair.
Jan 08, 2017 | Riccar Vacuums
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Where is the reset button on the riccar 300 upright?
If you are facing the back of the vacuum the reset button will be towards the bottom of the vacuum.
Dec 06, 2014 | Riccar Vacuums
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
Jun 18, 2014 | Riccar 8955 Upright Vacuum
Riccar 8905. where is reset button
hey RICCAR, PRESSING AND HOLD THE ON/OFF BUTTON WAS THE ONLY WAY TO SHOOT DOWN MY HP 533W
Sep 06, 2010 | Riccar Vacuums
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where is riccar reset button>
The reset button on your model 8955 is in the back, on the left side at the bottom. It is a white button
Jan 15, 2010 | Riccar 8955 Upright Vacuum
My riccar will not work
Reset button is located in rear near left wheel. A white button, push in with paper clip to reset
Dec 13, 2009 | Riccar R100 Vacuum
Riccar 1500p vacuum won't start
Oct 01, 2008 | Vacuums
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
52 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
