Question about Balboa Instruments Pool & Spa
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Posted on Apr 17, 2013
Jun 17, 2015 | Garden
Sep 26, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Nov 13, 2013 | Jacuzzi Home
Sep 09, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Apr 11, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
547 people viewed this question
