Broadband connection is blocked
SOURCE: wireless
as i'm not sure which combination of Fn and F key it is, go to network connections and select your wireless adapter, right clivk and select enable, it should then be active
SOURCE: HP Pavilion dv4000- Can't connect to wireless internet
Is your chipset wireless network program taking over?
Often an internal system program will take priority when connecting to wireless networks.
Think of it like siblings who squabble over attention.
If you can find any other programs which are acting in this manner, I'd suggest telling them "do not use this when connecting" and then see if you can then use your main program.
Also - is your network secured and / or hidden? Did you reset your router? Sometimes this helps, too. =D
SOURCE: Just received an HP Pavilion dv6-1245dx Notebook.
in dv6000 the motherboard stopped detected the wireless card,even new card will not fix this problem
SOURCE: driver for HP Pavilion DV6 for Inbuilt webcam Driver
Go to cyberlink.com download driver, you can also use Skype. Just remeber to check what version you have, this should be found in the manaul. Hope this helps
SOURCE: HDMI, and VGA on HP Pavilion dv6 1359wm, S-Video
you need something like this http://www.amazon.co.uk/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24 - but you may also need to see if the VGA display adapter supports the output, sometimes this also needs to be enabled to get it to work - other times it works just by using the VGA output switch - which will be one of the F keys look for a symbol of a screen and then use that F key and the FN key together to toggle the output from
<laptop only><laptop and VGA output><VGA only>not necessarily in that order.
The HDMI is a digital signal out and to convert to analogue for the TV will need an expensive convertor
Testimonial: "Thank you, they are digital TVs, just not HD, So still gotta go VGA."
