Nothing but problems with this oven; from delivery, to installation, to servicing. Electrical fire started from light/convection switch in right oven. Blew fire out, shut off breaker, called Sears. Took Sears Service three trips over almost three months to show up with the proper switch and fix that problem. Yesterday discovered a steady humming sound coming out of the back of the range. Shut breaker "off" then back "on" after a couple minutes, turned all commands "off" then back "on", but the humming hasn't gone away. Now what? (I'm not on Facebook).
SOURCE: error code E2F3
Traci, The error code means overtemperature, just what happened to you. It exceeded 575 degrees. Two things that have to be checked here. First the temp sensor itself, it should ohm out at 1080 at room temperature. If it's within specs, which I doubt, then the main board has to be checked for a welded or closed relay. I wouldn't use the oven. Catriver...post back.
SOURCE: bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted. I have experienced this problem before. The board is not serviceable and (unfornately) you will have to replace it. The board can run anywhere from $100 to $200 for a new one. Slightly less for a refurbished one. Prices will also vary depending on source. This is a repair you can do yourself if you choose to do so. If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you. Let me know. I hope this is helpful.
SOURCE: Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
SOURCE: my kenmore electric range 9621 shut down
check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
SOURCE: Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Thanks all for the quick responses. The model # for this beast is C970-330033. Until it's repaired, I'ill shut down the breaker and just use the gas top.
