Computers & Internet Logo
Anonymous Posted on Mar 12, 2013
How do i disable dos mode from my computer
When i attempt to open Internet Explorer, Wordpad configures and states cannot run program in DOS mode. I want to delete Wordpad and DOS mode.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 12, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
533
Points
19
Start control panel programs&features scroll until you see what you want to delete click on it & delete
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on May 31, 2008
SOURCE: DOS for gateway laptop model ML6720
Pls try to download boot98se.exe and thereafter it will automatically install itself to a blank diskette. That would then be bootable and usable as a DOS boot disk. If you are running some other Operating System, this page may help you with making a bootable DOS disk.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Anonymous
  • Posted on Oct 27, 2008
SOURCE: Problem acer 5052
Dear SIr or madame.
Please I would like to solve problem with my computerm, the screen got dark, so is very difficult to read the background.
how can overtake this essue?
Best,Lemos
Anonymous
  • 2559 Answers
  • Posted on Jan 07, 2009
SOURCE: where is tab key & alt key does not work in dos programs
Tab key is located on the lefthand side of the keyboard just above the Capslock key and says TAB on it,It should also have two arrows,One facing left and one facing right.
Try the other Alt key located at the other end of the space bar
Anonymous
  • 36 Answers
  • Posted on Jan 17, 2009
SOURCE: dos mode
to reformat, you have to boot from another source like a CD. you can't reformat a drive while it's being used, so get yourself an operating system disc and you can reformat/reinstall.
Anonymous
  • 481 Answers
  • Posted on Jul 14, 2010
SOURCE: MY MACBOOK IS ON DOS MODE
I suspect the only possible answer is "reinstall Windows."
1helpful
How do I disable DOS mode and Wordpad from my computer?
i don' think that's possible.internet explorer proberly corrupt.
I use Paradox Version 4.5 on my old Windows XP computer. Now I need a new computer that will have Windows 7. How do I install my Paradox 4.5. I've all ready tried everything that I can think of but no...
I use "DOS Box 0.74". it opens a dos window that you can run paradox in. Its FREE and works great, even in full window mode. Only issue I had was I toggle to DOS occasionally to clean up txt files and DOS Box has limited DOS commands.
I want to open imesh and it says it cannot open it with DOS mode on so how do you turn it off?
I can only give a generalized answer as you did not specify the Operating System you are attempting this with. Vista/7: Right click on the imesh application icon. Select "properties" and find the compatability mode tab or section. Select "run this program in compatability mode for" windows XP sp3.
That should fix the issue. DOS mode does not run Natively on any version of windows later than XP.
Fair warning: Imesh is quite outdated and belongs in the junk pile. Update to downloading through torrent sites with a program called utorrent (www.utorrent.com) and use sites like piratebay.org
1helpful
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
I need to download a program that requires windows and my computer says the program wont run in dos mode how do i get it to work?
if the program requires windows that means it was design to work with windows and not with DOS.. you may want to get an old version of the program that will actually run under DOS.. usually you may be able to do the opposite which is to run DOS program on windows.
if possible try to get a DOS version of the program you are trying to run, or better.. upgrade your operating sytem so you can run your program and possibly other DOS programs.
post the program you are looking to download and confirm what operation system you're running and I'll try to look for it with you.
Explorer.exe won't come up after downloading and installing new software
In my openion, Virus doesn't want to be killed by anti-virus :D You need to download DM2000 (disk manager 2000 of SeaGate) and run it in DOS mode to format Hard-Disk.
BIOS update (motherboard GA-6BX7+)
Please disable "BIOS Flash Protection" function in the BIOS or by Jumper. About the details, please refer to your motherboard manual.
refer to page 22 of THIS manual
If you "search" the word "flash" there are many references that may be of assistance if the jumper does not resolve issue for you
2answers
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Grand Canyon Tech
Grand Canyon Tech
