Question about Samsung Digimax 530 Digital Camera
Camera keeps bleeping and will not turn on
Camera bleeps and will not not turn on
5 Related Answers
Anonymous
SOURCE: Samsung Digimax L730 Digital Camera
This problem is usually caused by grit in the mechanics of the lense. To resolve the problem:
1. Ensure the lense itself is clear, removing any visible objects.
2. Try tapping / knocking the camera to dislodge any obstruction.
3. Failing this you can force the mechanics by turning the lense sections - however be careful when attempting this as you may snap the lense if turned too hard or the wrong way.
Words of wisdom from: Malhotra, Manmohan
Posted on Nov 05, 2008
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: My camera won't turn on.
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 22, 2009
Anonymous
  • 411 Answers
SOURCE: samsung PL 50 lens stuck half way
mechnism of the lens is deffective,get it serviced.
Posted on Mar 30, 2010
Adam Peake
  • 421 Answers
SOURCE: If i turn on the camera the lens gets stuck
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Posted on May 02, 2010
Anonymous
SOURCE: samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Posted on Jul 20, 2010
My Samsung ES63 camera won't turn on even though it's fully charged. It makes a weird bleep instead.
did the camera sustain any drops or water damage?
if not then i would recommend to take it back to the manufacturer and request a refound for the defective equipment.
Jan 31, 2012 | Samsung DigiMax Cameras
Samsung PL 50 lens stuck half way
Mar 29, 2010 | Samsung PL 70 SL720 Digital Camera
Bleeping
Do you have your camera set for continuous focus tracking?
Feb 26, 2010 | Canon PowerShot Pro1 Digital Camera
Samsung pl50 camera - lense wont go back in and wont turn on
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
When you turn the camera on it ,comes on and then bleeps and then turns its self off .also the lens will not close or go back in..the camera is a samsung s630/s730
Does this camera take SD or CF cards?
Maybe you have either a low battery, or a large High Capacity card that is not supported by your camera currently.
A firmware update might be possible to allow you to use the larger cards.
Jul 20, 2008 | Cameras
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Samsung Digimax 530 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
