Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
Wiring a hunter remote control for ceiling fan
Fan unit has only one black and white color wire remote has thre for fan,light and netural
5 Related Answers
Anonymous
SOURCE: installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Posted on Oct 30, 2008
Anonymous
SOURCE: Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Posted on Jun 15, 2009
extreme7528
Matt Wurth
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Posted on Oct 07, 2009
Anonymous
  • 5 Answers
SOURCE: Fan with remote won't work with wall switch. I
kjob, if you haven't figured you fan problem out yet, the must be set to the highest setting through the pull chain for it work correctly with the remote.
Posted on Nov 10, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Trying to replace a remote controller in a Hunter ceiling fan with a Harbor Breeze univer. need help with wire color code.
Did you try reading the directions that came with it? I can tell you that the black wire with white stripe coming from fan is the light wire.
Apr 01, 2016 | Hunter 52" Ceiling Fan With Light And...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter fan wiring
Oct 06, 2009 | Hunter Dryers
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Jan 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Installing a universal remote on a ceiling fan.
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Wiring in Ceiling fan remote. Lights flicker
dip switches are not on the same signal?
Sep 07, 2008 | Hunter 27185 Remote Control
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
71 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
