Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Wake on lan dell 6400 - Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
1 Related Answer
iqbal_del
Iqbal Husain
  • 655 Answers
SOURCE: Networking with LAN
The most laptop now comming with recovery software loaded on one of their disk partition (generally D: drive). So it will help you to get back all sofware and driver as it was issued by company.
So you can use this utility to get back your OS and drivers.
If this is not the case with you. then you should go the dell website, navigate the drivers and downloads section and enter your service tag no (not model no.) and then it will give you all the supported drivers for you laptop. Download as per your requirement. And install them.
Thanks
[email protected]
Posted on Mar 08, 2008
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Where did i get a free dell ispiron laptop lan driver
please try and search the following link for Dell support.
support.dell.com/support/downloads
You can also log onto :
support.dell.com
request in the query with your model number
1helpful
How to enable GA-EP43-UD3L motherboard wake on lan?
Most modern ATX motherboards should have a 3-pin Wake-on-LAN connector near the PCI slots and should included BIOS support for Wake-on-LAN power up,check the Power Management Setup for this option.
As i check in your motherboard manual there is not pin but it supports wake on lan so go to bios and enable power on ring in power managment,it should be enable by default.Next right click on your computer,then properties,then device manager(OR YOU CAN SIMPLY GO TO START->RUN AND TYPE devmgmt.msc and hit enter).Then find the network adapters,click on it,and click on your ethernet controller(it should be realtek,gigabyte something like that) and the go to advance and scroll(search) for "wake up on lan" "wake up capabilities" and make sure that is on or enabled AND YOUR DONE:)
Rotation of display at "wake up"
go to display settings n off roatation mode..
n make sure perfect resolution for ur notebook
Land drivers
www.dell.com support enter servcie tag and download appropriate driver
Changing OS from XP home edition to Xp professional
Get free program called driver max http://www.innovative-sol.com/drivermax/ its easy to use you just need to registar with email and stuff will find drivers for you ;-) hope this helps also is your wireless lan built into the computer or is it a plug in card look on keyboard for key with FN on press and hold this and look for key that looks like radio mast and press this at same time that is if you have the keys will look now for you on dell webby
2answers
Dell Inspiron 1525 with Vista
I'm out for the evening, but I'll be back tomorrow morning. Leave the info and I'll get you a solution.
Networking with LAN
Thanks
[email protected]
3answers
Turns back on
First, it would help to know a little about your system. Are you running XP? The major cause of reboot instead of shutdown is Roxio software. If you have it installed, you might note that the light on your CD/DVD drive stays green throughout the process. Alternatively, you may have "wake on LAN" turned on -- but this is unlikely unless you've been fiddling with BIOS settings. If it's Roxio causing the problem, you can find a patch here: http://www.roxio.com/en/support/ecdc/
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
