Televison & Video Logo
Sony FWD50PX1 trouble shooting codes
Turns off, indictor flashes four times
Posted by jack on
    Top Expert:
  • Televison & ... Master
  • 76,851 Answers
You're asking about the blinking codes to Sony TVs I assumes that posts this solution. If you wish to know more about blinking codes to many models of Sony TVs, check this link. Pull up older posts there.
Posted on Mar 12, 2013
1 Related Answer
Anonymous
  • 10515 Answers
SOURCE: I have a WS-55807 that
The code 2-2 does indicates a short protect fault, which is usually caused by a failure in the convergence section. This is a very common repair in these sets. The typical repair involves replacing the convergence ICs (integrated circuits), and testing/replacing two small pico fuses.
The replacement ICs for your set are part number: STKxxx-xxx and are available from www.encompassparts.com for $19.95 each (needs two). You will also need at least one (likely two) 5 Amp pico fuses. If you wish to repair this yourself, the ICs are located on the large heat sink on the center (Power) PC board. The fuses are also on this board, near the center, location numbers: FXAXX and FXAXX. You would need soldering equipment and very good soldering skills to replace these parts.
An image of the same would be ( the below one is a generic picture ) :-
If you were to call a local shop to repair this, the labor to replace these is roughly $250-275 (in my area) if the TV were brought in to the shop. Please add a trip charge if repaired in the home.
The fuses must be tested with a multimeter to see if they are bad. They are only $2.50 each, so most people without a meter just change them both. If the repair has any problems, like a solder bridge, you may need a meter to check them after that. A good magnifying glass helps prevent solder bridges (for me, anyway).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2010
2answers
T con board the problem?
Unplug the set for five minutes. Turn the set back on. That completes the RESET cycle and the system should correct itself. If not, it's time to take it into the shop.
I TURNED MY TV OFF AND IT DONT WAN TO COME BACK ON THE RED LIGHT IS FLASHING, I CHECKED THE FUSE AN IT LOOKS GOOD
how many times does the red light flash its referred to as blink code , thiss well help in trouble shooting.
There should be four options with sony cybersot DSC-T70
Some shooting modes don't have the same number of flash options. What shooting mode are you in?
Sony 51" wide projection tv stand by light flashing 10 consecutive times and wont turn on with remote or tv power button
Type in scearch bar, understanding sony Blinking codes it will take you to web site telling what each code stands for! Read how to trouble shoot in self-Dioanatic Mode.
2helpful
Will not turn on it will flash red four times but will not turn on
What is model. Give exact number of flashes. This is and error code.
Trouble shooting car
this is an OBD2 car and you will need a scan tool to find your code
there are many auto parts stores that will do it for free
2answers
Turning off the flash
This camera has four flash modes and each time you press the button the mode changes. As you press the button you should see the indictor in the upper left side of the screen.
1. In automatic flash, the camera will decide if you need flash or not. This mode does not have any indicator on the screen
2. Forced flash, this will cause the flash to be constantly on. The indicator looks (kind of) like a lightning bolt.
3. Slow Syncro, this mode slightly delays the flash and is used to lighten up the background more the foreground. The indicator looks like the lightning bolt with SL next to it.
4. No flash, this will turn off the flash. The indicator looks like a lightning bolt enclosed by a circle with a diagonal line through the lightning bolt. (similar to a no parking sign).
The mode you want is the circle and diagonal slash over the top of the lightning bolt.
If you don’t see the indictor changing on the screen the switch behind the button is malfunctioning.
Flash is not working ??????????????
Top Televison & Video Experts
Marvin
Marvin
