Question about Toymax Televison & Video
MY MAGNAVOX 42"LCDHDTV,POWERBUTTON GOES ON BUT SCREEN STAY BLACK
ALSO MAKES A CHURPPING SOUND
Posted by josereal35 on
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
2helpful
2answers
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
1helpful
My plasma screen goes black on bottom 1/2 of the screen
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
3helpful
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
1helpful
Screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY [email protected]
Televison & Video Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
