Question about Mitsubishi WD-52526 LCD TV
I have a Mitsubishi projection tv model wd-52526. The tv has sound but no picture. It will display channels or devices Is there a simple fix to this?
Posted by Lee Powell on
tycells
    New Friend:
No picture or a big black box covering the picture. If it is a big box covering the picture then you need to turn off closed captioning.
Posted on Mar 12, 2013
5 Related Answers
PurplieNicol
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
ken black
  • 179 Answers
SOURCE: Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Posted on Dec 29, 2008
Anonymous
  • 184 Answers
SOURCE: Mitsubishi WD-73732 TV
It could be a bad lamp but I've run into many of these TVs with bad color wheel assemblies. Also, if you are getting a dialog box coming up with these words," airflow blocked, TV will shutdown ..." that's a defective thermal fuse.
This is a job for a mitsubishi authorized service center. A tech can disassemble the light engine and confirm that the wheel is the problem. If you're still in warranty, great. If you're only recently out of warranty, call mitsubishi for assistance. Remember that persistance pays off when dealing with large corporations. You very seldom get what you're looking for on the first call or from the first person you speak to.
michtech
Posted on Feb 16, 2009
Anonymous
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Posted on Feb 17, 2009
Anonymous
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
19pfl4505d can't auto program
in main menu if using cable set the set to c a b l e before auto program is attempted.
Apr 09, 2012 | Mitsubishi WD-52526 LCD TV
Vizio no sound after storm
lightening surge can take out portions of the main board which processes and controls audio functions. Replacing the main board should solve the issue. www.tvcircuitboards.com should have the main board if not they can get it quickly.
Mar 02, 2012 | Mitsubishi WD-52526 LCD TV
Put in new blub and heard a zapping sound is bulb bad or tv?
Check the bulb is not damaged and is inserted fully into the socket. The bulb needs several thousand volts to ignite which would be the sparking noise you heard if not connected properly.
Mar 08, 2011 | Mitsubishi WD-52526 LCD TV
How do i replace lamp on a mitsubishi wd52526
The lamp replacement is a fairly simple procedure... First make sure the power is disconnected and the lamp is cool... There is a small cover on the rear left of the back of the TV (Lower corner)remove those 2 screws. Inside the cover will be the housing unit for the lamp. You simply loosen the 2 screws and slide the unit out. Replace the new lamp and make sure u put back on cover, There is an interlock switch on the cover that keeps unit from powering up if cover is not replaced.
Jan 30, 2011 | Mitsubishi WD-52526 LCD TV
WD 52526 I need a user manuel to install the lamp
Google to this websitie Encompass Parts Distrubtion
1-800-638-3328
Apr 14, 2010 | Mitsubishi WD-52526 LCD TV
Wd-52526 projection bulb has been replace but
If may be a power supply or ballast issue. The ballast feeds power into the lamp and it may not have enough power, or may not be able to FEED enough power into the lamp after it ignites it. That would account for the dim picture.
Feb 04, 2010 | Mitsubishi Televison & Video
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ws55859
Misubishi WD-5237
T.V. will come on and display the satellite channel guide and will change channels,but will not display picture. Could this possibly be bad spot in coil?
Mar 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD-52526 LCD TV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
