Loud clunking noise during wash cycle
Agitator barely moves during wash cycle and machine makes a terrible thud noise during wash cycle.
Posted by Steve Rivers on
  • Steve Rivers Mar 13, 2013
    Hi, It's a GE Profile top loading washer, Model# WPRE6150H0WT Serial# RM197932G
Geraint
    New Friend:
    Problem Solver:
  • 7 Answers
Hi What machine is this? and is there play on the stainless steel inner drum?
Posted on Mar 11, 2013
  • Steve Rivers Mar 11, 2013
    GE Profile. I'm at work so I don't have the model or serial # but I can get it for you later and yes there is alot of play on the stainless tub.
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
Anonymous
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
Paulo
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
Anonymous
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My speedqueen make a terrible noise during the wash cycle, what could that be
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 23, 2013 | Speed Queen AWS75NW Top Load Washer
Ge wpre6100g0wt washer makes load clunking sounds during it's cycle. Should we just call a repair guy?
Check this link :
Jan 23, 2013 | Washing Machines
Maytag Performa Washer niosy during wash-cycle. Spins OK and without any noise.
Check this link :
Jul 02, 2012 | Maytag Washing Machines
Make loud noise during spin cycle
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
623 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
john h
