Posted on Mar 11, 2013
Infocus lp425z projector pushes latop display to left quarter of output image
Recently acquired an InFocus LP425Z projector; it works quite well with a DVD player, with a bright and sharp image. However, when hooked up to my computer's VGA output (with the CableWizard adapter) the image from the computer monitor is compressed into the left quarter of the projected display. Talked to the help desk at the InFocus 800 line; adjusted the computer's resolution and made certain the connections were snug. No joy. I tried both CableWizard 2 and CableWizard 3; no change in output. This projector has the proprietary (non-standard) socket for connecting the VGA output with the CableWizard. Help desk suggested trying a VGA to RCA video converter in order to make use of the video input socket used by a DVD player. Does anyone know how to get this device working correctly with the regular VGA input? Thanks!
RevDave
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 13, 2013
RevDave
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
4438
Points
12
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
The image does not display on the projector from a laptop
make sure it's an analog signal. then reset the settings on the projector to factory default. toggle the f4 on the laptop. lastly, make sure the cable is good.
REMOTE
good luck. infocus has nothing having to do with any of the lp4xx series. they don't even have lamps. try ebay.
2answers
InFocus LP725
Hi there
Resetting the unit will unfortunatelly not work , you are facing replacing or repairing the Projector's Mainboard.
Quite expensive to do
Flickering color, color flickers in and out
Check connections, board, and unit itself around the Color Wheel.
Problem
Is there any lights that come on? or is it completely dead?
Cheers
Color Wheel
you'll have to replace it. bad news: infocus doesn't make them anymore. sorry
2answers
Problem with INfocus LP425z Colorwheel ?????
That unit has a bearing color wheel, if it was not stored proper, it could be sticking. That would explain the power cycling. giving it a bump start if you will. Yes you can open and inspect to see if color wheel "free wheels"
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
