Hi, Our Hoover Nextra HNV 6147 Washing Machine has stopped draining water away, it ultimately ends up flashing error code 3 (drain/pump timeout according to the manual). I've put a brand new drain pump on today and have checked all pipes for blockages and they're all clear. When the pipes are removed from the drum I can put a jug of clean water through the drum and it drains through quickly into a strategically placed pan. I've checked the connection to the u-bend and it's all clear and the water drains away nicely when I disconnect the waste pipe from the u bend and place it lower than the drum. Got to be honest I'm stuck now - I'm just about out of ideas. Any help would be appreciated. Cheers
SOURCE: WDI12C Machine Will Not Drain - Error Code E06
This is a useless machine. I had it and after about 14 months, in quick succession, the pump broke and then the timer broke. A friend with the same machine had the same experience. AVOID!
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
SOURCE: Error code 'FH' flashing -
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
