Tip & How-To about Nintendo Super Smash Bros. Brawl for Wii
To fix a scratched CD:
1) take a tube of toothpaste and place a dab on the CD.
2) Rub the toothpaste around the scratched area and let sit for a few minuets.
3) Take a slightly damp cloth and wipe the toothpaste off.
Note: do not rub in a circle, wipe off the paste starting from the middle, going out.
4) Finally, gently dry the CD with a towel, and play away!
Try the disc in another CD / DVD player.
It is important to make sure that the DVD itself is the problem, and not the CD / DVD player.
Cleaning a CD / DVD player is a much more intricate process that requires device-cleaning hardware.
Lay the disc artwork-side down so that you can easily clean the playing side.
You should always avoid setting a disc playing-side down to prolong its lifespan.
Gently rub the disc with a soft, lint-free cloth to remove all traces of dust and fingerprints. Always rub a disc from the center toward the outer rim in a light motion to prevent any other damage.
Apply a light amount of toothpaste to a cotton wool ball and gently rub the disc from the inside out.
You may need a few drops of water to make the toothpaste spread easily.
Cover the entire surface area of the disc, or at least the area that is scratched.
Toothpaste is a gentle abrasive that works well for fixing simple scratches.
Clean off the toothpaste with the cloth, once again rubbing from the inside of the disc toward the rim.
Try not to push too hard to prevent further damage.
Apply other kinds of light abrasives such as baking soda or glass cleaner if the sound is still distorted.
Remove the solution with the same gentle rubbing technique.
Purchase a disc-cleaning spray from a local video or electronics store.
These sprays are effective in removing any grime from the disc and filling small scratches.
hope this helps
hope this helps
