Whenever i connect the player to a usb port, it will not show up on the computer. the player shows that it is charging and says "connecting" but you cannot access the files on it. I have tried multiple computers(non modified) also, even though it says its charging, its not. I left it plugged in over night, but it still showed the same amount of battery life after unplugging it. Please help!!!
SOURCE: need to download music
take a look at the following link, you should find all the answers you might have regarding this media player. Looks like it has 'drag and drop' ability.
http://www.generalmanual.com/MP3-MP4-Players/Sony-NWZ-E438F-8GB-Walkman-Video-MP3-Player.htm
let me know if this does not work out for you i will attempt to locate more info
SOURCE: mp3 will not connect with my computer
I'm pretty sure I fixed a similar problem. Go to your device manager on your PC and uninstall the walkman driver. After this is complete just plug the walkman back into you Pc and the plug and play will download the driver again. This worked for me. My operating system is Windows vista.
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
SOURCE: nwz-e438f will not play, or connect to computer
Please try connecting the Walkman to a different USB port on the Computer and check if that helps.
Please make sure that there is no other USB devices connected to the Computer at the same time.
If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Keep the Walkman connected to the Computer for 4 hours to fully charge the battery. Then, check whether the Walkman is working properly.
Ensure that the HOLD switch is not activated.
If the issue still persists after performing the steps provided above service of the Walkman is required.
SOURCE: Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
yeah i have the same problem with my walkman other computers can read it but mine wont it says connecting but doesnt charge at all and i cant put music on it anymore
Two days into our cruise my Walkman MP3 player came up dead. Tried charging it without any luck. It will come up for about 15 seconds with "every moment has its music" and then dies. Computer does not recognize the device, not sure what is going on.
[email protected]
I have the same problem. After I plug it into the USB port, it says 'connecting' and then just stays there - the computer does not recognize it. However, when I connect it to my laptop, it says the hardware has already been installed. I'm thinking there's some kind of software that I don't have?
Mine says that it is full, but it doesn't charge. It says onnected USB (mtp)
I hypothesize that it's windows SP3 that does it, but I'm not sure.
