Question about Connex Radio Communications
Explain DA- EB-FC switch on connex cx3300hp
Switch, DA-EB-FC, please explain? DA is for CB channels 1-40 ? what is EB & FC ??
Posted by Michael S. Crookham on
5 Related Answers
Cary
  • 7 Answers
SOURCE: [email protected]
Having the same. New mic and antenna. Will not receive on cb but can on weather still.
Posted on Jan 24, 2010
Anonymous
  • 56 Answers
SOURCE: My friend would like to purchase a Connex CX 3400
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Posted on Feb 12, 2010
Testimonial: "Thank you so much for the feedback. "
JOHN BABA
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
Anonymous
  • 5 Answers
SOURCE: just installed a connex cx 3300hp not sure of
it should be am selector switch on d/a and hi band
Posted on Jul 26, 2010
Anonymous
SOURCE: Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Posted on Sep 05, 2010
My Cobra CB Radio Receives Fine But No Transmit
is it a total no TX. or just not getting out very far.?
could have a broken mic wire. or the CB / PA switch may be in a wierd spot try moving it.. are you getting the Correct RX frequency on the channels.. ie are you getting channel 20 on acutal ch 20. and if you switch to ch. 6 are you getting ch 6? if you could explain more..
Dec 11, 2013 | Radio Communications
Connex cx3300hp, what is switch DA-EB-FC ? DA is for ?
its just diffreent frequencies you can be on like lsb or usb no one uses thes da eb switches its mostly just there for looks not everyone you talk to has those so its just diffrent frequencies you can be on
Mar 10, 2013 | Radio Communications
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Need new codes for myb starview box please
ntl 00:7F CD 76 82 BB 22 0A C5 01:35 5E D6 40 6E AA 99 41 cw 00:D8 53 39 BD 3D CA 86 C1 01:27 77 A1 FC 8F 9D 34 76 ireland ntl 00:B0 B8 4F 04 E6 5F 87 80 01:A3 EB EC 07 D6 49 D2 EB
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Lost codes for euro vox
5A01
KEY 00-CF 53 0C 33 79 61 71 85
KEY 01-52 5E 8D 45 FC 75 F6 4A
THANKS BY XPOSE001
Dvb "the box" is not showing all channels
ntel.
0.3F B8 36 62 72 E5 E2 76
1.35 5E D6 40 6E AA 99 41
tw.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
cw.
0.D4 A3 5D EB 7B F3 69 59
1.27 77 A1 FC 8F 9D 34 76
Dec 15, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes for the north east (5c 01)
0=D4 A3 5D EB 7B F3 69 59
1=27 77 A1 FC 8F 9D 34 76
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
New starview telewest codes please
00- 93,14,d0,7e,5c,eb,74,4e 01- 30,80,b3,a3,fc,72,6b,3d
Nov 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
CODES
00= 93 14 d0 7e 5c eb 74 4e 01= 30 80 b3 a3 fc 72 6b 3d
Nov 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Transmission code
Here is the TSB from Ford:
Here it is... TSB 03-22-10...
FORD: 1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
2000-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
MERCURY: 1997-2001 MOUNTAINEER
This article supersedes TSB's 03-11-9, 02-13-8 and 02-08-2 to update the model coverage.
ISSUE:
Some vehicles built prior to 12/1/2001 may exhibit the following shift and engagement conditions:
No 2nd Gear
No 3rd Gear
No Engine Braking In Manual 1st.
Out of specification pressures controlled by the transmission main control valve body separator plate may be the cause.
ACTION:
Verify the condition, the main control valve body separator plate may need to be updated to the latest level. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
CAUTION: A NEW SEPARATOR 7Z490 MUST BE USED WHEN INSTALLING THE SPECIAL SERVICE KIT 7M203 OR ADDITIONAL TRANSMISSION DAMAGE MAY OCCUR. REFER TO THE PARTS APPLICATION CHART IN THIS ARTICLE FOR CORRECT SEPARATOR PLATE PART LISTING.
NOTE: THIS ARTICLE DOES NOT APPLY TO ANY OTHER CONDITIONS OR COMPONENTS THAT MAY CAUSE SIMILAR SYMPTOMS AND IS ONLY WRITTEN TO COVER THESE SPECIFIC CONDITIONS.
NOTE: AN IN-LINE SERVICE FILTER IS NOT REQUIRED TO BE ADDED OR REPLACED FOR THIS TSB.
Verify that one or more of the following conditions exist.
Low Line Pressure While In Drive At WOT
No 2nd And/Or No 3rd Gear
DTC P0732, P0733 Or P1762
Install Kit (3L5Z-7M203-JA) to update the main control valve body assembly, refer to the installation procedures found in the kit.
Reinstall the main control by continuing to follow the installation steps listed in the Workshop Manual, in-vehicle service, main control valve body.
After completing the procedure, verify the condition has been corrected.
Clear all DTCs.
Part Application Chart
Vehicle Application Engineering Description Qty. New Service Part Use on Transmission Application 7000 -Reference Only-
95/96 Models ONLY
95/97 Models Separator Plate to Case Gasket 1 2L5Z-7C155-AA ALL
95/97 Models Separator Plate to Main Control Gasket 1 2L5Z-7D100-BA ALL
95/96 Models - ALL Plate - Valve Body Separator 1 F5TZ-7A008-CA 95GT-AA/BA/CA/DA/EA/FA/ GA;96GT-BA/CADB/EB/FA/ GA/HA/KA/MA/NA
97 Models ONLY
97 2.3L Ranger Plate - Valve Body Separator 1 F77Z-7A008-AB 97GT-GC
97 3.0L OHV Ranger/Aerostar Plate - Valve Body Separator 1 F77Z-7A008-AB 97GT-EC/FC/MC/NC/RE/SE
97 4.0L OHV Ranger/Aerostar Plate - Valve Body Separator 1 F77Z-7A008-CB 97GT-KE/LE
97 4.0L OHV Explorer/Mountaineer Plate - Valve Body Separator 1 F77Z-7A008-DB 97GT-KF/LF
97 4.0L SOHC Explorer/Mountaineer Plate - Valve Body Separator 1 F77Z-7A008-EB 97GT-AE/BE
1998-2001 Models ONLY
98/01 2.5L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-DA 98GT-GA; XL5P-CA
98/00 3.0L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-EA 98GT-EB/FB; XL5P-AA/BA
98/00 4.0L - EI Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-FA 98GT-KB/LB; XL5P-DA/EA/FA
98/00 4.0L - EI Explorer Plate - Valve Body Separator 1 1L5Z-7Z490-GA 98GT-CB/DB; XL2P- EA/FA
98/00 4.0L - SOHC Plate - Valve Body Separator 1 1L5Z-7Z490-HA 98GT-AA/BA; XL2P- CA/DA
2001-2002 Models ONLY
2001/2002 2.3L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-AA 1L5P-CA
2001/2002 3.0L Ranger Plate - Valve Body Separator 1 1L5Z-7Z490-BA 1L5P-AA/BA
2001/2002 4.0L-SOHC - ALL Plate - Valve Body Separator 1 1L5Z-7Z490-CA 1L5P-DA/EA
ALL MODELS
1995-2002 ALL as Listed Above Valve Body Service Kit 1 3L5Z-7M203-JA ALL
May 27, 2008 | 1998 Ford Explorer
Radio Communications Logo
165 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
