SOURCE: epson r800 inkjet will not turn on
I leave mine unplugged overnight. Next mornig I plug it in, turn it on and restart Windows. Give it a shot.
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
SOURCE: Flashing red lights
this means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
SOURCE: epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
