Depending on set up there's a chance because you ran it out of gas the bowl is dry? Get some old school lighter fluid pull out the plug squirt some into hole , doesn't take much. Reinstall plug quickly and give it a pull and see what happens
I wish I could give you an instant fix, but I can't. Do you have spark? If so then its either your fuel pump or the CPS, crank position sensor. If no spark then it could be your coil.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
you can try and remove the old gas the carburetor and perhaps the fuel filter are most likly fouled with gunk from the old gas. When gas sits, over time it forms a thick gummy deposit that can clog carburetors, and anything else. try fresh gas with some carburetor cleaner (NOT the kind in the spray can) mixed in. It may need to have the carburetor rebuilt or replaced.
Check the compression, pull the spark plugs one at a time if more then one. If you don't have a compression gauge, you can put your figure over the spark plug hole, be mindful that before it blows it's going to **** so make sure that you don't hurt yourself leave a little gap so your figure doesn't suction down to tight. If your getting compression it should **** and blow pretty hard. If it seems to have good pressure and suction. You might need to check your timing, also make sure that you can feel air moving out the exhaust, might not be able to with the pipes on it but if it won't start and your getting everything else it needs to run gas,spark, etc. It has to almost be timing or compression.
