Question about Frigidaire FWS833A Top Load Washer
Washer out of balance - Frigidaire FWS833A Top Load Washer
Posted by ramontrevino on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hi ramontrevino - I personally recommend making sure that when you are loading the washer to make sure it is not too little clothing or too much since it could create an out of balance load. If this is not the case, then the unit may possibly have a broken or damaged shock absorber, bearing or pulley issue. At this point, I would recommend connecting with an experience technician to determine the underlying cause.
Posted on Mar 13, 2013
Is there a video showing how to balance front load washer or simple instructions on how to balance the tumbler as it is hammering during spin cycle
Thank you for your inquiry, Jay Kraemer!
From the information you have provided you would like a video on how to balance your Frigidaire frontload washer. I was unable to find any information on balancing your washer from your manufacturer. This could mean that it is not a simple DIY job. You may be able to perform a generic search online for any information except I would recommend having a professional technician out to accurately balance your washer. This will help to avoid any future issues. -Matt
Feb 17, 2015 | Frigidaire GLTR1670A Front Load Washer
How to balance
By "balance", do you mean balance the load or balance the washer to keep it from wobbling on an unlevel floor?
You can adjust the front feet of the washer to "level" it with the floor.
Sorry I didn't quite understand your meaning. Hope you can use this info.
Jan 27, 2015 | Washing Machines
Why do i have a red blinking light on my motor when its in off position
Probably washer is smart enough to detect the out of balance.
Try to distribute the clothes in a balanced maner as soon as you detect it is out of balance.
Aug 29, 2014 | GE GTWP1800DWW Top Load Washers
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
May 06, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Affinity washer will spin as if off balance
well there's a counter weight that could be loose or broke or the support hangers for the tub may be broke or loose.
Sep 17, 2009 | Washing Machines
Drum out of balance after repair on 20722 kenmore washer
THESE WASHERS SIT ON A SKATE PLATE PICK UP ON THE TUB A TURN IT A BIT AND TRY IT ONCE IT IS BACK ON THE SKATE PLATE WILL OPERATE PROPERLY
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Frigidaire FWS833A Top Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
