Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Right front burner allows for selection of large element or small and the large doesn't work anymore
Posted by Will Lawler on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Posted on Mar 13, 2013
5 Related Answers
Jimster
James Greene
  • 240 Answers
SOURCE: Frigidaire glass top
You will need a wiring diagram and a multi-tester (volt meter, etc). Find the diagram for the elements, trace your wires to that switch, and check for voltage coming out of that infinite switch. If you have voltage, then its your element (85% chance its the element anyway). Good Luck.
Posted on Nov 05, 2008
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: doubel element
If only the outer ring of the element is getting hot then the element is bad. The elements should have a 5 yr warranty that covers the part only so check your owners manual.
Posted on Oct 06, 2007
tech expert12
  • 521 Answers
SOURCE: burner on range will not turn off
  1. all these problems are given in the link below and the solutions with diagram is given in it
  2. http://www.applianceaid.com/micro.html
  3. A common flow chart for microwave repairs
  4. A breakdown of a newer counter style microwave
  5. Door switch caution and repair help
  6. How can I get at the handle screws on my microwave to replace the handle? This has a common GE style microwave picture to help you.
  7. How to install a common over the range microwave
  8. Important Disclaimer
  9. I set something on fire in my microwave and now it is dead...help!
  10. My GE OTR ( Over The Range ) microwave is running but will not cook
  11. My Frigidaire microwave is flashing a fault code in the display...what's up?
  12. My GE microwave is flashing a fault code in the display...whats up?
  13. My Panasonic microwave is flashing a fault code in the display...what's up?
  14. My Sharp microwave is flashing a fault code in the display...what's up?
  15. My Whirlpool microwave is flashing a fault code in the display...what's up?
  16. My microwave light bulbs burnt out...caution!!
  17. Ohm testing an capacitor
  18. Some common Microwave FAQ
  19. Some common components and how to check them with a ohm meter - like magnetron, high voltage transformer, high voltage capacitor, door switches and high voltage diode.
  20. Stainless Steel Cleaning
  21. Sparks from inside the oven area....why?
Posted on Aug 27, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
Anonymous
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
229 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
