SOURCE: Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Testimonial: "Thanks so much, really appreciate the quick response!"
Hello wsmith454 - From what you are describing, more than likely the bottom drawer possibly has a faulty latch. If I was in your position, I would personally suggest contacting a professional to accurately assist with the repair or installation of the part.
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
