Question about Sharp Microwave Ovens
In case of unavailability of touch panel regarding any model of your microwave you can simply asked your repairman to install micro touch buttons (easily available and can be fixed) on the base of touch panel than repest the panel over it. It would work like the same.
Posted on Oct 07, 2022
SOURCE: sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Posted on Dec 27, 2009
Testimonial: "thanks for your help, real fast return."
SOURCE: Sharp Microwave R246. Power Failure
Press
the "Off/Clear' button to cancel anything on the display, and reset the
microwave. This is a soft reset and will simply get you out of any
program you have started. Press it when the cooking complete reminder
appears on the display.
Perform
a hard reset. Pull the plug out of the wall power supply, and wait a
moment. Plug the microwave back into the wall power supply to reset
any anomalies with the microwave's memory. You will need to reset the
time of day if you perform a hard reset. This should help fix the problem.
Posted on Sep 09, 2011
SOURCE: Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,
leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Posted on Jun 11, 2012
SOURCE: sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using
the number pads. Press "AM/PM" if applicable, and press "Start" or
"Clock" to confirm.
However if the problem persist the display board
main control board is faulty
Posted on Oct 03, 2012
