Question about R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop
Update wireless driver on targa 1029 laptop - R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop
Driver aspire one D270
Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Apr 17, 2012 | Acer Aspire One AOA150-1029 Notebook PC
Targa 3100 video card..what does the red led "on"
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 25, 2011 | Pinnacle TARGA 3000 (136123060) Video...
Wireless on targa doesnt detect wireless networks
There could be a problem with the driver for the adapter or the hardware itself. The first thing I would try is go into the control panel and then into the device manager. Then look for the wireless adapter and remove it. Then re-boot the computer and windows should detect the adapter and re-install the drivers. If that does not work you could also try and locate the updated drivers from the manufacturers website and install those. Also remeber that it may be a simple as you have turned the adapter off. Netbooks usually have either a switch or FN key and another key combination to turn the adapter on and off. So look on the netbook for a wireless switch or one of the function keys might have a antenna symbol above it. If you find one then try holding the FN key and press the function key....that will trun the wireless back on.
Dec 19, 2009 | Computers & Internet
How to enable wireless network on targa computer
Harry, If you mean to access WiFI, then all you have to do is buy a WiFi dongle. Install it and then insert the dongle into the USB port. and you are on. But, if you want to run a WIFi hot spot on your PC, then you need to install a wireless router so that other devices having a WiFI capability can connect to it. You need to set up a WireLess LAN for which there exists a wizard in Windows.
Sep 14, 2009 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
No executable program in graphics card drivers folder
depend on your OS as to how you go about this but basically click "start" the right click on "my computer" select properties. this will get you to system properties..slick the "hardware tab then the "device manager" button.
Find "display adapters" and right click on your current video card and select update driver. tell it no to search the internet then click on the "install from a list or specific location (advanced)" you the should come to a window where you can "browse" to and select the folder where your new driver is located. it will look for the .inf file and install the driver. This is a walk through using XP its gonna differ a bit on Vista but its basically the same thing.
Feb 11, 2009 | Targa Computers & Internet
No executable program in video drivers folder
I have a TARGA TRAVELLER 1574 X2 LAPTOP which is about 2-3 years old. I was using it last week, everything was fine. I put it away, but when i came to use the laptop later on, the screen was completely blank. The power button was lit up and everything else was ok, but no power was going into the monitor. Ive tried to see if it had gone into sleep mode, but to no avail. Ive even tried to reboot with a WINDOWS XP disk but nothing. Do you have a solution to my problem?
Feb 11, 2009 | Targa ProEdit T3K 6221 Graphic Card
Hi..
Try this website http://www.service.targa.co.uk/
Jan 06, 2009 | Computers & Internet
Hi i need a help! i am looking to find '' '''''' drivers for targa traveller 1512 for xp edition thank you very much!
This link should get you to the downloads page, but if not, use the below instructions.
http://www.service.targa.co.uk/ is where you'll need to go, further navigation does not change the address bar, so you'll have to follow step-by-step.
  1. Select "Targa Mobile PCs" under the ModelFinder on the right.
  2. The Targa Traveller 1512 should be the 4th down.
  3. Once on the FAQs page, you should see 3 tabs above the picture of the laptop, Select "Downloads"
  4. The XP package is the first download in the list.
Dec 31, 2008 | Computers & Internet
Targa Card.....Please Help!
If your PC tells you the driver is not found, the card itself is working but the problem is in the software.
Chances are that a microsoft update caused this problem, specially if you pc is set to automaticly update windows.
Try re-installing the targa drivers, this might help.
Otherwise try to find out if there is a driver-update available on the relevant website of Targa.
Jun 30, 2008 | Targa Computers & Internet
R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop Logo
71 people viewed this question
Top R.A.M. Computers Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a R.A.M. Computers Computer and Internet Expert? Answer questions, earn points and help others
