Question about Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator
How many cu ft is the 795.73954300
I wnt to know how many cubic feet is the Kenmore 795.73954300
5 Related Answers
Anonymous
  • 242 Answers
SOURCE: Kenmore refrigerator and unknown capacity specs
It should be 25 cubic ft. It is usally the first few numbers in the model number.
Phil
Posted on Apr 10, 2009
Anonymous
  • 106 Answers
SOURCE: how many cubic square feet is our kenmore
25 cubic foot
Posted on Sep 27, 2009
Testimonial: "I recieved an answer in less than 2 minutes!!! Thankyou Thankyou!!! My kenmore refrigerator model #51582200 is 25 cu ft. Now I can list it and sell "
Anonymous
  • 1304 Answers
SOURCE: Would like to know specs
i believe this model is a standard size unit,
and should be very easily repalced by almost any manufacturer today
this unit has a capacity of 3.5 cubic feet on the drum
Posted on Nov 03, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Kenmore 26 cu ft side by side refrigerator 51673100
I think the Adaptive Defrost Control may be your problem part number 12566102 You may find it inside the fresh food compartment and behind the controls where you adjust the tempertaures. I will return with photos and links, Sea Breeze
Posted on Dec 20, 2009
Testimonial: "Great Help Thanks!"
Anonymous
SOURCE: How many cubic feet does Kenmore model 1069552882
freezer is frosting up ,freezing or not letting airflow to refrigerater
Posted on May 23, 2010
How do you convert inches into cubic feet ?? ex.23.4 in., 22.7 in., 33,6 in. into cubic feet. ?
Easiest way is to first convert your inches to feet, then multiply:
23.4" is 1.95 feet
22.7" is 1.89 ft
33.6" is 2.8 ft
1.95 * 1.89 * 2.8 makes 10.32 cu ft.
Jun 13, 2016 | Kenmore Refrigerators
How many cu yards to cover 196 sq ft to a depth of 2 1/2"
Hi Bob:
1 cubic yard is 3ft by 3 ft by 3 ft.
3 times 3 times 3 equals 27, so
1 cubic yard equals 27 cubic feet.
2 1/2 inches divided by 12 inches equals .2083333 feet
196 square feet times .208333 feet equals 40.83333 cubic feet
40.83333 cubic ft divided by 27 cubic ft equals 1.5123456 cu yards.
Ta Da!!!!
May 01, 2015 | Refrigerators
64 quarts of soil equal how many cubic feet?
1 Cubic Foot = 29.9220779 Quarts [Fluid, US]
1 Cubic Foot = 25.71404638 Quarts [Dry, US]
1 Quart [Fluid, US] = 0.0334201389 Cubic Feet
1 Quart [Dry, US] = 0.0388892508 Cubic Feet
So roughly about 2.1 Cubic feet
Mar 07, 2015 | Scotts Company Scotts Miracle-Gro Potting...
What is the cubic feet of the Kenmore refrigerator Coldspot 106.5706602
According to your model number, this refrigerator has a total capacity of 25.2 cu. ft. It has 15.4 cu. ft. in the refrigerator section and 9.8 cu. ft. in the freezer.
Oct 20, 2014 | Kenmore Refrigerators
Kenmore model 795.7500401 need to know cu sq ft
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 27, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
What is the cubic feet of this 20-25?
actually a bit bigger than 25 cubic feet
Total Volume 25.5 cu. ft. / 722 liter Fresh Food Volume 15.5 cu. ft. / 439 liter Freezer Volume 10 cu. ft. / 283 liter
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
