SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
SOURCE: how to remove jets from american standard jetted
Jet trim usually unthread counter clockwise out of the wall fitting
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
