In recent heavy rains water is coming in on drivers side of the car, Have done a hose test (pouring hose water over car) to try and find leak to no avail.
Under the door trim there should be a plastic film stuck to the steel and over all the holes. Water running down the window glass drip straight into the car if this film is damaged or removed. Check the the drain holes onder the door are clear and not blocked with mud and other gunk. There will be 3 holes elongated and about 3/4 " long close to the outer skin. Clean them with a paddle pop stick or similar. Check that the door rubbers are touching and sealing by placing a film of vaseline around the door opening and then close the door . There shoulod be a continuous mark in the vaseline .
SOURCE: rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
SOURCE: Car is leaking antifreeze from underneath of car
watch for leaks and follow them after you drive i would geuss checking your thermostate housing both parts, the hoses that go to the heater core by the throttle body and the hose that goes to the throttle body, im guessing this is the turbo, if it is a non turbo it would be a hoses the waterpump or the oring that goes into the waterpipe on the front of the block, just get in there and take a good luck and remember the rules of gravity =) good luck man and if you need any parts for it let me know we got alot of these parts cars out in our yard
SOURCE: water leak on fwd passenger side after every rain storm
If your car has a sunroof, there are drains from the front corners of the sunroof, and they drain down the sides of the windshield pillars, and then empty out on the ground.
What I would do is open the surnroof, and pour water into the front corners, and then oobserve where the water drains out. If you have a difference in water drainage between the left and the right sides, I would think that you may have loose sunroof drain. They commonly come loose at the sunroof corners. This will allow the water to pass down the windshield pillar, and onto the floor.
Also, I would check the condensate drain tube for blockage. Pull back the carpet, under the glove box, and fins a black hose that pokes thru the firewall. Pull it out, and see if it is blocked internally. If this tube is clogged, water will build up in the heater box, as the black tube is the drain for the heater box.
One of the two above solutions will cure your problem. I see both quite often.
Thanks for choosing FixYa for assistance.
SOURCE: Coolant leak in VW Golf mark 5 1.9 TDi auto DSG
There is, however, an air outlet into the driver's foot area. If the heater core is leaking, the air coming through the heater core will carry the droplets into the entire air ducting system. The driver's foot area may be the closest outlet. If it smells like coolant, you need to replace the heater core regardless of where in the cabin the coolant is coming out.
SOURCE: Water leak on the passanger side of a 1999 Jeep Cherokee Sport
The first place I would look is the floor board caps. Make sure one or more of them aren't pushed up, allowing water to enter the cabin. Also, because your defroster is probably on while it's raining, make sure the A/C drain plug isn't clogged. It's a small rubber fiting that sticks out from inside the firewall, behind the engine. Simply pull it out and clean it. When you pull it out, you might be surprised to see water coming out of the hole!
Just a couple things to check. I hope this helps! :)
-Jason
