Let me start with explaining the basic construction of a Harddrive.
This is what the Dell Inspiron 1545 harddrive looks like on the outside,
1)
http://support.dell.com/support/edocs/systems/ins1545/en/SM/hdd.htm#wp1109848
Scroll down to the heading - Removing the Hard Drive
Go down to the second illustration under this heading.
Number 3 points to the Hard Drive.
2) Another look. This time at a basic Harddrive that fits in a laptop computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1455518&CatId=2681A) See the round shiny disk? This is a Platter.
There may be from 3 to 6 Platters.
Platters resemble CD or DVD disks. They are usually made of metal, or glass. On the Top surface, and Bottom surface they are coated with a magnetic media.
Usually a ferrous substance. (Iron like)
Immediately below the Platter shown, is a Read/Write Head attached to an Actuator Arm.
The Read/Write Head cannot be clearly seen.
The Actuator Arm is the slim triangle shaped part.
(Has three holes in it, and the big end has a round shape in the middle)
There is an Actuator Arm, and Read/Write Head, for the Top surface, and the Bottom surface, of every Platter.
The Read/Write Head does as the name implies. It Reads information off of the Platter, and Write information to it.
{ It arranges the magnetic medium on the Platter, when it is writing to the Platter }
More information on the basic construction of a Harddrive,
http://computer.howstuffworks.com/hard-disk.htm(6 pages)
The Platters may spin up to 5400, or 7200 Revolutions Per Minute.
(RPM)
The Read/Write Heads are spaced VERY close to the Platters.
(From my understanding, approximately 1/10th the thickness of an average Human hair. An average human hair is 3 thousandths thick.
{ .003 )
Due to the speed of the spinning Platter, and the closeness of the Read/Write Head to the Platter, there is a cushion of air formed in-between the Read/Write Head, and the Platter.
When the computer is not on, the Actuator Arm is in a parked position.
(Seen in the Tigerdirect link)
This means the Read/Write Head is AWAY from the Platter.
When the computer is on however, the Read/Write Head is located right above the Platter.
(Probably to the outside edge, and the Sector/Tracks where the basic Windows Boot files are located)
When you dropped the laptop apparently the Read/Write Head/s wiped off some of the magnetic media on the Platter/s, and damaged the boot sector.
Try this,
http://support.dell.com/support/edocs/systems/xlob/dtg/en/software.htm#wp1114294If to no avail buy another harddrive. Set the laptop so that it's ready to have another harddrive installed, THEN remove the old harddrive, and install the new one.
Keep the old one to install into an inexpensive external enclosure, and copy off all of your personal info,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783Then plug it's USB cable into any available USB port, on a working computer.
For additional questions please post in a Comment.
Regards,
joecoolvette
