Went thru all the steps as the manual says select the power button select the rinse/spin button select low spin speed select warm/cold water temp. set the end of cycle signal to softer. Push extra rinse button 4 times within 5 sec.to start the cycle. The door will lock,and filling will begin. Nothing happens, Then if I press the start button it just goes thru the rinse/spin cycle. Can,t get the cleaning cycle to start.
SOURCE: Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
SOURCE: The machine starts going thru
Hi
Thanks
for using FixYa. oL flashes when the
machine/motor control detects a load size that exceeds the washer’s capacity. Open
the door lids to clear display, remove excess laundry, then restart the cycle. Please
do accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
