Can rocker arms cause heavy knocking noise
what is the motor from? Typically if you changed out all those parts already and its still a heavy knock, you're looking at crank bearings. How did you change the connecting rod bearings without the crank bearings? or are you referring to something else? I would assume its connecting rod bearings are the issue, if main bearings go you would see an issue in oil pressure.
