Televison & Video Logo
Scott McCutcheon Posted on Mar 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The standby light keeps flashing on and off. The TV won't go on. Any help would be appreciated.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 09, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994801
Points
237762
The inserted video have no details about the brand name of the TV. Anyway, understand that these blinking are fault indications. Count the number of blinks occur at one time switch on. If you wish to get more details about the blinking codes, check this link. Form the number of blinks, you can get an idea about which section circuit is faulty, and will make troubleshooting more narrower. Check the above linked site patiently. Blinking codes and troubleshooting procedure to many brand TVs are given.
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Sep 23, 2007
SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
Anonymous
  • 4889 Answers
  • Posted on Aug 19, 2008
SOURCE: TV problem
Sure. Can you tell me how many times it blinks before each pause. Please do provide this information correctly as this will help in effective diagonosis of the problem.
Regards,
Sai.
Anonymous
  • 700 Answers
  • Posted on Apr 20, 2009
SOURCE: Relay clicks, but No sound, No picture.
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Anonymous
  • 1015 Answers
  • Posted on Jan 12, 2010
SOURCE: Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Testimonial: "Thank you for your help. After replacing the colorwheel, the tv came right up.!!!!!"
Anonymous
  • 2992 Answers
  • Posted on Jun 08, 2011
SOURCE: TV won't turn on with
The flashing timer light blinks out a code, where it flashes some number of times, pauses, then repeats. The code indicates what fault is keeping the set from coming on. Unfortunately, all the codes tend to mean that there is some electronic problem with the TV. Unless you have some electronic servicing skills and the necessary equipment to troubleshoot the problem, you'll need to have set checked by a professional. For any code there can be many causes, so I can't offer any other advice.
This might be a good time to check sale prices on LCD sets. Let a technician check the set and give an estimate for the repair, then decide.
Finlux tv won’t turn on standby light keeps flashing
https://www.sony-asia.com/electronics/support/articles/00011057
I did see another suggestion when you unplug the tv hold the start button 30 seconds while tv is unplugged.
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Tv does not come up standby light keeps blinking
It seems there is no information in the manual here http://www.finluxdirect.com/content/ebiz/shop/resources/pdf/46S8030-T.pdf
So you may want to attempt to talk to their support. They have free on line chat here Finlux Direct Help Centre
Good Luck
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
1helpful
Standby light flashes and TV won't turn on. Have to unplug it and wait for a bit then plug it back in and TV turns on. Quite a delay though. Then after TV is turned off, standby light starts...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
2answers
Tv help
This is bad. You need to either be under warranty on these big screen TVs or get the service manual. Especially since this is an off brand.
2answers
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
