Question about Frigidaire Ovens
How to unlock oven door model number cfef372ec3
SOURCE: Can't unlock the lock lever after cleaning
just push the clear/off button on the stove
Posted on Dec 31, 2007
SOURCE: Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Posted on Aug 31, 2008
SOURCE: unlocking oven door??
Try pressing STOP/CLEAR, then pressing in and holding the door switch plunger for 6 seconds on the upper right hand corner of the door.
Posted on Sep 17, 2008
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Nov 30, 2015 | Ovens
Sep 01, 2014 | Whirlpool Ovens
Aug 13, 2014 | Hotpoint Ovens
Jun 05, 2014 | Frigidaire Ovens
Apr 06, 2014 | Stoves Ovens
Dec 13, 2010 | Frigidaire FFEW2725LB Oven
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
Feb 28, 2010 | Kenmore Ovens
Nov 18, 2009 | Kenmore Ovens
Dec 15, 2018 | Frigidaire Ovens
46 people viewed this question
