Question about Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer
PMV common circuit
What is it and what does it do
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
Sep 05, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Pride Wrangler PMV has ringing sound when in drive mod? Help
It sounds like the wheel bearings need lubrication or they might not have a fitting to be able to lubricate. If there is no way to lubricate the bearings, they will have to be replaced with new wheel bearings.
Jun 09, 2014 | Pride Wrangler Pmv 4 Wheel Scooter
Horn will not sound pride hurricane
The horn is a a small peizeo horn. You can generally get them at radio shack. The horn voltage is 24v. Before you run and get a horn, you need to see if the horn accidentally was disconnected due to a bad solder joint or the wire had been accidentally pinched and cut from a previous service. This horn generally does not go bad. The button on the dash is usually the culprit. While you have it apart you need to look at the button closely. The best way to check this this to have the scooter on and touch both wires in the bottom of the switch with a screwdriver and see if the horn sounds. If it does, replace the switch. If it doesn't, then it is either the horn or a bad circuit. Depending on how comfortable you are messing with electricity. You can apply direct voltage from the batteries with a jumper wire and see if the horn works or you can use a voltmeter to check the circuit. I usually just use the jumper wires. It's fast and easy. If horn works then it's in the circuit, if it doesn't you have to start with replacing the horn.
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
Scooter keeps stopping randomly. The battery level near to the speed lever drops quickly to red, scooter stops. Turn it off then on again and fine for a bit - then same happens?
These units are 24 volt systems. If the voltage at the controller drops below 18 volts the controller will cut out. Shutting the unit off and back on resets the controller. Since your battery gauge is dropping into the red when accelerating your batteries are suspected to be bad. If the batteries LOAD test fine then check your battery harness and circuit breaker wiring for a loose and / o r hot connection after riding it.
Oct 28, 2013 | Hurricane Pride Pmv Mobility Scooter Candy...
PMV Hurricane 5000 scooter was left out in rain. Batteries are good but it now wont run, nothing works no horn no lights...zip
Could be water in the key switch. Try taking the tiller shroud off and shorting the wires underneath the key switch. Also, while you're there, check to see if there is a Printed Circuit Board. If there is, there may be a small glass fuse that may have blown. Hope this helps.
Dec 23, 2012 | Health & Beauty
I have a Pride Mobility Hurricane PMV, None of the left side signals, or parking lights work. I think I have it down to the console board. I have 12 volts going in but nothing when I activate the left...
Hoping your problem is in the wiring to and from , or the light itself , usualy when the board goes , nothing works... make sure you test every contact point for juice to and from , before you discard the possibility...!!!!
Jan 05, 2018 | Pride Mobility Products Hurricane PMV...
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
Wiring has been disconnected need to rewire pride hurricane pmv scoote. Need service manual or wiring diagram.
Hello, If you need any manuals or wiring diagrams go to;
http://www.pridemobility.co.uk/ipb/
Username : pride
Password : access
Hope this helps...
Jan 26, 2010 | Hurricane Health & Beauty
Pride hurricane pmv just replaced batteries everything was fine went up and down the driveway (flat surface) and it stopped working
Are any of the lights coming on? If so, are any flashing, and if so, how many times or is it constant? Check to make sure the freewheel lever is not bumped which will cause a no-go status. Put in freewheel and place firmly back in drive (located at the rear of the scooter).
Go back in and make sure all of the snap connections are tight. Undo them and redo them, don't rely on a visual inspection. Check the circuit breaker; push it in to reset. If it has tripped, you will feel a click when you push. Check all the fuses.
Jun 25, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer Logo
119 people viewed this question
Top Upper Deck Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you an Upper Deck Toy Expert? Answer questions, earn points and help others
