Pick up messages away from home
Since you didn't specify the model of your Uniden 5.8GHz system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
SOURCE: how do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
SOURCE: retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
SOURCE: Cannot retrieve messages on answering machine from
Here is a link to the manual download page of Uniden. Select you phone model number and download.
