Question about Just Wireless Bluetooth Headset Wireless Headset
I got a new phone and I can't pair my BT-38K1 Just Wireless bluetooth
4 Related Answers
Anonymous
SOURCE: Need PIN for Just wireless bluetooth
I threw away my instructions for my bluetooth just wireless model #bt-5 and I cannot find the pin number i need to add to sinc up my phone, can you help?
Posted on Nov 06, 2008
Anonymous
SOURCE: how can i pair the just wireless bluetooth headset with my phone
with the headset off, press & hold the power button for about 9 seconds until the indicator light alternately blinks red and blue. Set your phone to search for a new headset or bluetooth device. When it finds the headset, the passcode shoudl be 0000
Posted on Jun 04, 2009
Anonymous
  • 5 Answers
SOURCE: pair to a sony ericsson w760a to a just wireless
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Posted on Apr 24, 2010
Anonymous
SOURCE: My BT-10K pairs and operates in phone mode with a
CANT CONNECT TO PS3
Posted on Aug 06, 2010
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Nov 07, 2013 | Digix BT-100 Portable Bluetooth Wireless...
Attach phone
hi there. first switch on the bluetooth of your phone . then switch on the on button of your bluetooth device and keep it pressed for few seconds till the time the power lightgets on and now in your phone go to the option search new device .once ur phone detects the bt 38 name get it paired and it will start working
Oct 29, 2013 | Just Wireless Bluetooth Headset - BT-38
Not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Jan 20, 2012 | Genius BT-03A Bluetooth Headset
Hi?
You can goto bluetooth options in samung and disconnect the BTHS and delet it from the paired device.
To pair the BT to Nokia , put the BTHS in pairing mode by pressing the push button on the bt and watch the led stops blinking.
now gp to BT options in your nokia mobile and search for BTHS.
password is 0000.
After pairing go to options and connect.
Jul 26, 2008 | Motorola Mobility H350 Wireless Headset
Just Wireless Bluetooth Headset Wireless Headset Logo
1,302 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
