Clothing Accessories Logo
A
Anonymous Posted on Mar 08, 2013
V32a00001000 lamp bad - Clothing Accessories
Alec Oren Orris
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Sep 10, 2015
Alec Oren Orris
Contributor
Level 1:
New Friend:
Answers
43
Questions
Helped
31940
Points
66
Https://parts-e.com/Toshiba_V32A00001000_Lamp.html
https://www.encompassparts.com/item/7714884/Toshiba/75007110T/Y-66_Lamp_V32a00001000
Please post your questions in the correct category , with a proper subject line , followed by a complete question .
If you are done , please delete this question from this category .
Both bRAKE lights on my 2004 Buick park avenue will not work but the middle one does
WELL 2 OR 3 GOOD ARE 2 BAD LAMPS.
OR TRAILER HITCH HACKS FAILING.
not sure me if lamps there are all BCM controlled 2004
fuses good.
im reading your manual now on line.
USA car
stop lamps. they call it but is brakes.
it shows up to 6 lamps there all wired in PARALLEL
so if one works all must work,
if not bad lamps or bad wiring (connections) there.
NO BCM ,just 1 fuse and 1 stop switch, cave man old skool brakes.
fuse marked STOP.
bad wiring, but some folks let lamps fail 1 by 1 until someone yells
hey bud, yah's lamps be dead.
On a 2005 Jeep Liberty, what is the fuse number for rear tail lights? No longer have manual.
USA car, must we guess, #1 fact to know?
so front parks work and rear parks(called tails wrong) only rear bad and side parks good? cars can have 10 parking lamps. do they all fail., a key fact to know for what's wrong.
is real license lamp dead too (3 park rear)
I have KJ jeep service manual open now, (PDF) owned .
Daytime Running Lights - If Equipped<<< got this????? DRL
the uses guide is free from jeep 24/7, no need to work blind. ever.
causes for rear dead
  • BCM failing
  • fuse 9 and 7 blown ,7 is left, so both are not blown.
  • park relay bad.
  • g304 ground bad,
say no to all 4
#5 is 2 bad lamps, buy them put them in.
g304 bad kills lots of lamps rear os is not that.
not told at all
engine OK and drives perfect and head lamps work ,high and low beams.
nor if front parks works
no if DRL is on the car (an options)
does heater blower work//
does radio work,
do dome lamps work doors open.
does the IP cluster work right.?
4 turn sigals all work and hazards.
stop lamps work
reverse lamps work.
if all works , but rears
then fuses are not blown
BCM must be good, or the park relay dies and all parks fail not just rear.
there rear lamps are both burned out or the REAR G304 ground is bad.
but g304 runs most things on rear,so it can not be bad.
so 2 lamps burned out, we test the lamps now.
not telling all good and bad, the answer is way too long
electrics are a complex tree structure.
Drivers side light is out and its not the bulb
are you talking Parking lights. all lamps work? cept one?
there are park(tail-running) blinker, brake, and fog.
my guess is side lamp means the actual car side parking lamps/.
there are huge numbers of lamps for park inside and out.
like 20, the inside lamps are DIMMable.
if all 20 odd lamps glow and one dont, it can only be.:
1: bad lamp.
2: bad socket to lamp
3: wires cut to said socket.
i use a thing called a voltmeter to see what part is bad.
got one,? $10 at walfart?
FOG LIGHTS WILL NOT COME ON CAR
bad fuse.
bad switch
bad wires
bad connectors
bad grounds to lights
bad lamps, (not both at same time, but seen it many times)
what we do? we use a voltmeter and not guess.
we measure across the lamp , turned on
12v, lamps dead.
0volts, power to lamps dead
then work back to find loss point. easy huh?
Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
1helpful
Wd-52628 bad lamp or bad ballast?
you cant - unless you have another tv to test it in. May be a ballast or the cooling fan for the lamp is not working.
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
1helpful
2answers
If my samsung dLp HLM 507,has no lights,no power& the lamp is tight in the socket.Could it possibly be the BP-96 lamp? I've heard there's some sign of life when the lamp is bad.this set's dead
90% of the time the lamp is bad when the lamp is bad a lot of the time you will here a buzz sound by the lamp its trying to trun on the lamp but cant. also look at the flashing lites on the front of the tv it should give you code
1helpful
Have a 51 inch vivitek dlp.picture cuts out.error code says lamp is bad.
Most probably the lamp is bad anyways the ballast supply voltage to the lamp and could be also bad, if you hear a noise coming from the back go ahead and replace the lamp. if the lamp is good you just keep it sooner or later you will use
Jose
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Top Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
