Question about Frigidaire 15 cu. ft. / 425 liter Chest Freezer FFC15C3A
Need diagram for thermostat for chest freezer
A green wire with slide clamp cant remember where it goes
Posted by siddmac on
John Tripp
  • Frigidaire Master
  • 4,656 Answers
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire. HERE
If you have questions please let me know, Thanks Sea Breeze
Posted on Mar 14, 2013
1 Related Answer
mike cooper
  • 884 Answers
SOURCE: need new green led bulb for chest freezer
If it's only the power indicator, you don't need to replace it, really. If you feel the need is overwhelming, try Maplins or RS. You may even find one on eBay or at your local recycling centre on a dumped freezer
Posted on May 02, 2012
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Nov 04, 2014 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Holiday chest freezer lcm070lc
There are only three wires, aren't there? One is a safety earth, probably green or green and yellow. It goes on the spade attached to the metal of the thermostat body. The other two are a live and switched live. They go on the two spades that come out the plastic body. If there happens to be a third, it will be an alarm signal wire. Connect in any order you like. If the compressor comes on and the signal light, all is well. If the signal light does not come on, and the compressor switches off at -12c swap 2 of them. If none of this happens, switch 2 of them.
Apr 21, 2014 | GE Freezers
My chest freezer bush cf143gb works ok but the green light does not show it is
Good day James.
There must be a loose cable for the green light to come on. Your thermostat might need replacement especially if doesn't go on defost which happens automatically.
Feb 12, 2014 | Bush BSCF145 Chest Freezer
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
Is there a diagram for my kelvinator chest freezer? i need to repair a wire that fell off during our recent move
If the wire is green it's a ground wire and can be attached to any metal screw that is near that area
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 11, 2012 | Freezers
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Jul 10, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Frigidaire 15 cu. ft. / 425 liter Chest Freezer FFC15C3A Logo
304 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
