Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mitsubishi WD-52626 and just replaced the bulb but there is still a yellow tint to the screen? Is there another part that needs to be replaced?
Posted by akvincent07 on
  • akvincent07
    akvincent07 Mar 10, 2013
    The picture appears to be much brighter and more clear than before I replaced the bulb. However, there appears to be a yellowish tint to the picture. It is especially noticeable when the image is supposed to be white. Could this be the Optical engine? Since it is a rear projection TV, I don't believe it has a blue LCD unit but I could be wrong.
Robert Smith
    Champion:
  • 213 Answers
2 Related Answers
Anonymous
SOURCE: Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Posted on Nov 18, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: I just replaced a 915P026010
Is the Lamp Fan running ?As far as that goes is all Fans running and have you Pressed reset button?
Posted on Dec 17, 2009
Yellow tint on projection mitsubishi sl4u
The polarized glass for the Green LCD panel has gone bad, and require to be replaced.
Oct 05, 2015 | Mitsubishi Sl4u Colorview 3 Lcd Projector...
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
Dec 11, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Want does yellow light mean
If I'm not mistaking I believe Mitsubishi shows the yellow light to indicate new bulbs needed and or overheating. Most common is overheat, but may actually be a bulb replacement required.
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73733.pdf
That is the manual for your TV
Mar 10, 2011 | Mitsubishi WD-73733 73" HDTV
WD 62531 picture has predominately a green/yellow tint that is overwhelming. Is it possibly the color wheel. No noise, back all the color out and black and white picture is OK but still has a little yellow...
chevyss555,
It sounds like you have a bad optical engine. I have a tip at
http://www.fixya.com/support/r4251975-replace_dlp_light_engine
This should help you complete the repair as well as tell you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 01, 2011 | Mitsubishi WD-62531 Projection Television
Mitsubishi wd 65731, replaced bulb, after about 10 minutes screen starts turning yellow
If the screen is turning yellow from the centre out, then the blue LCD unit is burning up. Check that there is good airflow to cool the optics. It will not recover if that is what has happened unfortunately.
Nov 23, 2010 | Mitsubishi WD-65731 65" HDTV
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
