SOURCE: Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
SOURCE: cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out. The manual for the 9881 can be gotten here:
http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it. Don't forget to save it to your system. It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
SOURCE: Accessing aux port on Alpine CDE 9881
If you happen to have the tool which allows you to remove your head unit from the dash use it. If not go to crutchfield.com and get one it's useful for any audio enthusiast. Once you have the tool pull the head unit out on the back of the unit there is a cable that is black with a blue connector tip. This is what you plug your cable that you got from your audio dealer into. As for making the cable accesible you may have to drill a hole in your dash or run the wire around and out the glovebox which is also common and suggested for your particular car.
SOURCE: alpine
YOU MAY BE ABLE TO GET A HARNESSADAPTOR. IF NOT GET AN "ISO" PLUG FROM YOUR FACTORS, AND FOLLOW THE INSTRUCTIONS ON THE PACK, 1 PLUG IS THE POWER PLUG SO FIND THE SWITCHED LIVE, CONSTENT LIVE AND GROUND FROM CAR SOCKET. THE YELLOW IS CONSENT/MEMORY RED SWITCHED, BLACK GROUND EARTH, THE SPEAKER LEADS ARE PAIRED BY COLOUR YOU CAN TEST THESE WTH A 9V BATTERY TO FIND WHICH ONE IS WHAT, THE SPEAKER WILL BUZZ
SOURCE: How do you
By re-reading the complete User's Manual (which I downloaded for free). The directions on how to set AUX + SETUP to OFF were contained in this manual. I had been looking at the Quick Reference Guide (not the complete Manual) which came with the receiver.
I was told if you updated your ipod or have a newer version it wont work im having the same issues trying to find the old versions of itunes to see if it helps will post if it does
